# of speed sensors?
Old Mar 9, 2009 | 10:04 PM
ni$mo350's Avatar
8th Gear
# of speed sensors?
I'm trying to order it and one site is giving me the option to replace 2 and one is giving me only one. How many SS are there exactly? Thanks in advance.
Old Mar 9, 2009 | 11:12 PM
MurdaZ's Avatar
im thinking two for the front wheels. think our tl uses the splines on the wheel hub for a speed reading....rather than final drive gear....why are u getting them replaceD?
Old Mar 9, 2009 | 11:26 PM
juanclopez2786's Avatar
it has 2 speed sensors in the transmission. there are 4 sensors, one on each wheel for the ABS/TCS system. thats whats used for speed reading for the TCS system.
Old Mar 9, 2009 | 11:58 PM
jokerjuice's Avatar
hey if you take off the acura emblam in the back would it have 2 holes or its glued on??
Old Mar 10, 2009 | 12:31 AM
itd have 2 holes.
Old Mar 10, 2009 | 12:31 PM
ni$mo350's Avatar
8th Gear
Long story short. I was stuck in my house for 2 weeks straight in a snow storm and needed to get out. I got chains prior to the storm and I double and tripple checked the tags on the bags to match my tire size and they still seemed loose when I put them on but then again I wouldn't know because I've never had to use chains before (prior WRX owner) So when I was trying to get out of my street the chain broke and wrapped around my axle. My TCS and ABS lights came on and I took it to Acura of Portland to have one of my tech friends there put it on the lift and check it out. He said it wasn't the TCS/ABS sensors because they looked fine and then we cleared the codes and turned the car on and they came back and he traced it back to the VSS.
Thanks are the 2 VSS different or do you get two of the same?
Old Mar 10, 2009 | 12:59 PM
their different. .
Old Mar 10, 2009 | 01:26 PM
ni$mo350's Avatar
8th Gear
their different. .
Perfect thanks for the quick reply.
SidhuSaaB
May 30, 2020 12:40 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
joflewbyu2
Oct 8, 2015 11:16 AM
STL TL-S
Sep 23, 2015 08:52 PM
DS2000TL
Sep 9, 2015 09:26 PM
