Slight Knocking sound.
00 TL-P with 115... So my car is acting up lately. I dont know why but it kinda seemed to knock slightly when i accelerated. But I couldn't really tell. So I put it in drive held the brake and press the gas. I got this knocking sound. I just got the motor mounts changed not even a year ago. I was wondering if it was CV Joints? Or maybe something with my alignment. Cause I need some super bad
could you locate where the knocking come from ?Open your hood and listen ....It might come from your valves or if you do not change your oil frequently then you could have a slush oil in your engine that cost the lacking of oil 's flow .......
05 C230K & 09 135i 6MT
What the hell, guys? If he wonders if the knocking could be a CV Joint, and he obviously knows what a CV joint is, why does everyone keep fingering gas? I've used 87 in my TL for most of the time I've had it and never has it EVER knocked with it. But that aside, the knocking is obviously much louder than some pinging from bad gas.
If it makes a "pop" noise when you turn one way or the other, it could be a CV joint.
If the engine is "knocking" fairly loud, I suggest you get a professional diagnosis on that pretty quickly. If you haven't felt a loss of power, it's not the gas. But you could be doing further damage.
Hi I have a 2002 TL and it started doing the same thing. It sounds like a susipension knock or pop BOTH when I accellerate and slow down. Could it be a loose brake pad or CV joint? Not worse when turning...
Again only one little 'pop' or 'knock' (not from the engine) when I speed up or slow down?
when holdig the car stopped and you get noise at idle or with rpm - may be valve adjustment time- Did you get the water pump timing belt service yet?
emailnatec
29
09-28-2018 04:27 PM
STL TL-S
09-23-2015 08:52 PM
