Shudder when trans shifts from 1st to 2nd gear
Hello,
I have searched and searched this forum for my exact problem and have not found it.
I have a 2003 Acura TL Type S with 163,000 miles on it. When I take off from a stop at light to moderate acceleration the trans shutters when shifting from 1st to 2nd gear and then is fine. If I accelerate under anything more than the moderate acceleration it shifts clean into 2nd gear. All other shifts are smooth with no problems under any amount of acceleration.
I have done a 1x3 fluid change with Redline D4 but it did not do any good. If anything it is slightly worse. But still it does not do it under heavier acceleration.
Any help would be greatly appreciated.
Is it just a shutter, or does it slip at all?
If no slipping, my money is on motor mount(s) and possibly tranny mount as well. I've seen a handful of threads, one by myself as well, where tranny shudders, and it's the mounts.
If the fluid made it feel worse, could just be the tranny shifting more firmly, thus making it feel worse with it shutters due to the mount(s).
Thanks! That would make more since to me. It seemed strange that it would be a slip under low throttle but not slip at all under heavy acceleration. I will give the motor and trans mounts a look today and report back.
Yeah, as Chevelle66 said.....check the mounts. The passenger side upper mount and front tend to wear out quickly.
When were they last replaced ? Definitely the first place to look.
Just a theory, could be completely off, but my guess would be the weight shift of the heavier acceleration keep everything somewhat pinned down, so no shutter.
Luke5500, I have the exact same problem. Let us know how you fare with the mounts. I'm hoping it's not something more $ such as the transmission (or torque convertor). It also doesn't seem to happen in D4.
I might have to check out my motor mounts as well. I have a similar sputter under light load; however, its usually in 3rd and 4th gear. I recall seeing someone mention to check the engine mounts, but I didnt see any tears. Going to check tonight to see if there are any leaks from them...
It's possible, but I've always thought it was due to the increase in line pressure that higher throttle application creates.
Hey guys, if the mounts have not been replaced within the past 50k or 5years, they are likely shot. It's hard to check the front and rear, but the side is easy to see if bad. Our TL's are notorious for bad mounts...which can cause a shudder at slower speeds. A good place to start and eliminate as a problem, IMO.
Hello,
If you've got the time, this is explained in better detail over in 3rd gen. Look up redline racing atf, and the optimum per-centage of redline racing atf.
Yeah, replace them and see what happens. Good Luck !!!
nats007 (09-10-2013)
Thanks for all the feedback guys. I had it on a lift yesterday and the rear trans mount was bad. I replaced it but it still shudders. I still need to check the upper mount to see if it is bad. Will report back once I do.
mine seems to do the same thing...i hope u fine out and let us know... tks
those looking for motor mounts, I just ordered this off ebay:
http://www.ebay.com/itm/170793976599...84.m1423.l2649
They should arrive next week and will be going in over the weekend.
![Crazy](https://acurazine.com/forums/images/smilies/crazy.gif)
Also, are there any alternatives to the DEA mounts besides the $300 non-hydraulic mounts available? These never seem to last long
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
the light shudder shift 1-2 that goes away with more throttle is often
a simple need for trans fluid service and pressure switch cleaning
redline atf is not the way to go for this type shudder!
the new honda dw1 atf gives best results for this problem
you can manually clean the shift selenoid switches or run some motor purr or seafoam trans tune for 100-200 miles then
do a full 3x3 fluid changeout = trans holds 7.3qts
also replace the external filter as much crud will be in it after cleaner
I thought that the pressure switches were for 3rd and 4th gears? Will cleaning them have an affect on the 1-2 shift?
I have done a 3x3 with dw1 (not all at once -- over several months) - but the problem remains.
Thanks!
Thanks!
Have ya checked the mounts yet ?
How many miles are on the car....and when were the mounts last replaced ?
Try pulling the shift solenoids and clutch pressure switch to inspect for build up on the screens.
Welcome 03hondaodyssey !!!
Some more specific details on your vehicle and it's tranny may be helpful.
What all have ya done up to this point in the way of PM and attempted fixes ?
I've got the 1-2 shutter issue as well. The motor mounts were checked and replaced as necessary during my recent timing belt change (about 5k miles ago) and will be doing a 3x3 and filter change in the near future (need a bit of warm weather). Will also be looking at the shift solenoids and clutch pressure switch while I'm at it. Will report back when I've don this (could be a while, so don't hold your breath. Motivation and time is an issue on top of the weather.).
Completed a 1x3 change and also replaced the filter (will be doing 2 more 1x3 changes in the upcoming weeks). I noticed a slight improvement in the 1-2 shudder issue, although I only really feel it when accelerating slowly.
I didn't notice any improvement in my 3-4 slip (didn't mention that issue earlier). This mostly occurs when cold. I'll be pulling and cleaning the screens soon and may look to replace the pressure sensor.
Nicks2001tl (02-26-2014)
Mr.Helpful Diagram
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I would like to report that I tried cleaning the upper solenoids on a 99 TL and although I didn't see anything the filter screens I sprayed brake cleaner inside of them and manually actuated them with the battery to test them, Went for a test drive and unsure if it was going to take second gear it suprised me when it did it nice and smooth.
The next day did a drain and fill to find out it was overfilled by 2 quarts![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Then another test drive and no slipping or anything abnormal. A week now running perfect.
Check and clean your solenoids !
So, do the '00+ have the solenoid screens? I searched a thread from quite a while back and while these were identified on the '99 4-speed AT, no one indicated definitively if the '00+ 5-speed AT had them.
While I don't have any CELs, I am considering changing my 3rd & 4th gear pressure switches to see if that helps with my 3-4 gear change "flair". Trans doesn't slip once in 4th, but the revs go up slightly (~200 - 400 rpm) before 4th grabs when the trans is cold.
3rd and 4th gear pressure switches are very easy to do and a relatively inexpensive DIY project. Some guys on third gen side have been doing it for preventative maintenance. And yes the 00+ have solenoid screens. In addition check the negative battery terminal wire from the post to the ground for fraying or corrosion. Replace if bad.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
