Shakey steering wheel
Old Jun 7, 2009 | 11:05 AM
Eddystone's Avatar
I had new cross-drilled rotors and pads installed and had them on for about a month until I realize that the direction is wrong (installed my a mechanic that never installed cross-drilled before) so I had him redo them and now the steering wheel shakes when breaking at high speeds.
Whats the problem? how can this be fixed?
Old Jun 7, 2009 | 12:00 PM
hANDYcaptd's Avatar
It's the Halladay season!
May need to re-bed the pads.
Only thing I can think of, since the rotors L and R rotors were swapped.
Old Jun 7, 2009 | 12:02 PM
Eddystone's Avatar
Sorry but what does re-bedding the pads mean?
Old Jun 7, 2009 | 12:06 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Bedding-In Your Brakes
Old Jun 7, 2009 | 12:14 PM
Eddystone's Avatar
Thanks, I will it a couple of weeks to see if it goes away.
Old Jun 7, 2009 | 01:07 PM
tlzib's Avatar
Well i installed new rotors and pads thinking it will cure my steering wheel shake and high speeds when braking and its still doing it urggggg.
Old Jun 7, 2009 | 01:37 PM
Eddystone's Avatar
Could need alignment or wheel balance.
Old Jun 11, 2009 | 06:04 PM
spoiler900's Avatar
ive got the same thing on my car, its a 2001, but im not sure why because i just bought it used back in february. let me know how you fix it. maybe a front end wheel alignment?
Old Jun 12, 2009 | 02:22 AM
tlzib's Avatar
Got new tires and an alignment, now im driving smooth as silk.
Old Jun 12, 2009 | 06:36 AM
fsttyms1's Avatar
If it happens when you brake its a rotor issue. Have the pads and rotors turned at minimum, best is to replace.
Also rear rotors can cause it as well so dont just assume since you did the fronts and it still does it it should be fixed.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
EvilVirus
Dec 10, 2015 07:38 PM
04tler
Sep 10, 2015 04:03 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
