Seatbelt wtf
Old May 6, 2012 | 03:32 PM
MilwaukeeDave's Avatar
Seatbelt wtf
So today all the change fell out my pocket on the way into work when I punched the throttle. I guess a dime rested right on the seatbelt fastener and when I took my belt off the dime fell inside somehow. Whats the quickest way to get this out?? Really have no desire to drive home w no belt and get pulled over for it.
Old May 6, 2012 | 03:38 PM
Here's a pic. I tried putting my belt on before I realized it was in there and it jammed up. help!
Old May 6, 2012 | 03:51 PM
Anyone before I buckle my shit into the passenger side just to cover me?
Old May 6, 2012 | 04:31 PM
Edward'TLS's Avatar
6G TLX-S
Since the coin is now sitting flat at the bottom of the buckle, the only solution is to take apart the buckle assembly.
Old May 6, 2012 | 05:29 PM
U need torx 10 security bit. Which I don't have FML. I ended up pulling the center console, raising rear of seat and lowering the front to expose the buckle bolt. 14mm wrench to remove the gold bolt. Once it was off I pried the dime back to a flat position and it was STILL STUCK by the spring mechanism. So I stuck a nail file beside it and pried till it fell out. Now on change goes left pocket only fuck that was crappy.
Old May 7, 2012 | 02:10 AM
01tl4tl's Avatar
Change goes in the flip down drawer with `Not an Ashtray` printed on it
Old May 7, 2012 | 11:24 AM
dreem1er's Avatar
deal with it
Get 5 point racing harness
Old May 7, 2012 | 11:27 AM
dreem1er's Avatar
deal with it
And you can get a set of security trox at an auto parts store...if ask they say no because they no have no idea where they are standing, go to the tool section and usually a like 20-50 bit set will have the security trox head, or hardware store but i haven't had luck finding them there
Old May 7, 2012 | 02:18 PM
Change goes in my pocket. That's where I had it but the acceleration made it slide out. From now on change goes in LEFT pocket. Lesson learned. 5 point harness isn't needed I don't race. I was actually in a parking lot when this happened.
Old May 7, 2012 | 11:17 PM
dreem1er's Avatar
deal with it
try using a set of precision tools like the ones for pc repair, or hobbies...all you really need is a thin probe to move it around and thin long tweezer to grab on should come right out
Old May 8, 2012 | 02:42 AM
Edward'TLS's Avatar
6G TLX-S
There is no need to buy any special tools, because I can pretty well assure that MilwaukeeDave won't ever let this to happen again.
Old May 8, 2012 | 03:22 AM
Lol today I put my change in my lunchbag. Problem solved forever. I usually only have change for vending machines at work anyways.
Old May 8, 2012 | 02:39 PM
dreem1er's Avatar
deal with it
tell the people at your job to upgrade to the vending machines the take credit cards
Rapture
Oct 4, 2015 12:05 AM
E92Vancouver
3G MDX (2014-2020)
Sep 21, 2015 02:32 PM
iCrap
Sep 11, 2015 06:21 PM
ahsm
Sep 9, 2015 08:35 AM
