!! Seafoam in oil !!
~~~ SKY'S THE LIMIT ~~~
ok so i know there are trends about this---but question for you guys
i wanna put SEAFOAM in my oil to clean the engine
i have a oil leak from im thinkin is the rear main seal
its leaking from where the tranny and engine connect by that inspection plate there
wud it be ok to put seafoam in my crankcase---it came to my mind that if i did put it in there that the seafoam wud make my oil leak more
just a thought that came to my head
WHAT DO YOU GUYS THINK ???
thanks for the help
thanks for the help
sure its possible it can cus it to leak more if it removes dirt that maybe clogging the leak. your best bet is to stick with a synthetic "high mileage" formulated motor oil to help swell up the seals. and stick with *W30 oil.
How much do you leak? also pop open the oil cap and take a look at how dirty under the valve covers are.
well it only leaks after i drive it---if i look under the car when i pull in my driveway i can see it drips every 5-6 seconds-----my opinion is its ptetty bad
i opened the oil cap and it seems to look pretty normal in there ya know
sooooo you wud say NO to seafoam in the oil due to it leaking more then or what ?????
there he is---i was waiting for ya to respond to this man
i guess i shoulda just PMd ya directley for a answer
but by all means man---describe whats on yer mind
what wud u do if it was yer car ???
i plan on getting the seal fixed in a few weeks
but for now im saying----should i seafoam the oil to clean shit out OR should i wait till i get the seal fixed to do ANYTHING ???
THANKS MAN
ok,,how about a day before it gets fixed,,seafoam it good!!
so all the grit and crud is removed with the old oil..reducing possibility of damage to the new seal
I dont see it causing an increase in a seal leak--
the idea that sludge in a TL engine---- not some 30 year old sludge chevy, is holding the seal intact....cmon guys lets get real
IBankMouse
Jun 13, 2020 12:53 PM
acuratl26
Apr 23, 2020 07:30 PM
