Sagging Front Bumper
Old May 24, 2008 | 03:31 PM
tehboxzor's Avatar
Hey new to the forums here.
so as the title states my front bumper is sagging, anyone know how to fix this?
some background info: my sister crashed the car a couple years back (a huge fender bender) and she totally messed up the front bumper, we had it fixed but now its starting to sag, my sister still drives the car so she might have crashed it again.
my specific question would be i guess, how to uninstall and reinstall the bumper correctly?
Thanks!
Old May 25, 2008 | 10:26 PM
Rajca's Avatar
wham bam thank you ma'am
is their any frame damage? pics would help a bit. check if all the clips/ screws are there
Old May 25, 2008 | 10:30 PM
VoLLy's Avatar
Meridian
Yeah, Post a picture up. It would help a lot!
Also are there huge gaps in between the bumper and the fender areas?
Old May 26, 2008 | 01:24 AM
Gfaze's Avatar
S E L L
Most likely the bumper was not mounted correctly or the shop took shortcuts and didn't fix it how it's supposed to be done.
Old May 26, 2008 | 01:30 AM
03aspec's Avatar
Old May 26, 2008 | 11:29 AM
rob-2's Avatar
there is a bolt in either wheel well that might need to be tightened and/or is no longer there. Aside from that there might be clips missing that hold it on at the front. Just by the rad. Pull back the plastic covering over the front of the engine bay (runs the entire length covering the lights too) to see if anything is missing.
Then post pictures of your findings.
Old May 27, 2008 | 10:38 PM
tehboxzor's Avatar
Pictures coming Thursday. camera's MIA right now.
Old May 27, 2008 | 10:53 PM
tehboxzor's Avatar
oh and when i post pictures help me decide.
Sell...for an accord coupe or altima coupe or keep and mod it out....
just check out the condition first.
Old May 27, 2008 | 10:56 PM
VoLLy's Avatar
Meridian
wow, a potentially broken bumper will determine if you get a new car or not?
Old May 30, 2008 | 08:05 PM
cyde7399's Avatar
get a bra!
Old May 31, 2008 | 09:24 PM
myron's Avatar
Originally Posted by cyde7399
get a bra!
hahahaha I entered this thread to say the exact same thing
Old Jun 2, 2008 | 10:26 AM
acutee's Avatar
Front bumper is hang by the two removable metal L-shape frames. Each frame is mounted with 3 screws right under each headlight. The frames themselves are also the clips for the bumper. Each side, the 3 screws hold each frame to level the bumper high or low manually, they also hold the headlight. If you or someone has removed the headlight before, I am sure you know what I mean of the L-shape metal frame under each headlight.
It sounds to me the bodyshop didn't do the job properly; or believe it or not, they did not install the bumper with the metal frames. You can re-adjust the bumper and tighting the screws without completely removing the bumper if the metal frames are there. To access to those 3 screws, you need to remove 1 screw in the wheel well, one screw underneath the bumper and one plastic clip. Slightly pull out the bumper, then reach to those 2+1 screws with a ten-inch extension. 1 screw is right on the side, easily removed without an extension.
Old Jun 2, 2008 | 07:39 PM
tehboxzor's Avatar
my dad said forget about it, looks like were trading up for an audi a4. bye bye my tl and Vtec. hello audi.
i know. spoiled kid right?
Old Jun 3, 2008 | 01:13 AM
Gfaze's Avatar
S E L L
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
leerbgdup
Sep 6, 2015 11:01 PM
Sixers12
ILX
Sep 6, 2015 07:54 PM
robowarrio
Sep 1, 2015 09:25 PM
