TiMiNg BeLt....
Old Jun 2, 2008 | 04:35 PM
2ndgentl's Avatar
TiMiNg BeLt....
Im mechanically inclined, but thought that I would ask first before doing it. I got the timing belt, tensioner, and water pump for my tl. Is there a DIY page or is there something I need to know before tackling it?
Old Jun 2, 2008 | 09:08 PM
fsttyms1's Avatar
Sorta. Look for southerns timing belt thread.
Old Jun 2, 2008 | 09:41 PM
01tl4tl's Avatar
iirc the thread is in gen3 and titled: 105k service completed
by: Southern
This is a pain job if you have never done a FWD water pump timig belt job
not much room to work- and takes a while to do
Adjust the valves while you are in there!!
If unsure after reading DIY - consult a few shops for price on labor
Old Jun 3, 2008 | 08:04 AM
bibledriver's Avatar
Something is missing...my
Have you replaced any timing belts before? Have you done mods of sorts?
Old Jun 3, 2008 | 08:42 AM
2ndgentl's Avatar
2ndgentl
Yes, I have changed the timing belt in my older 1993 integra. Im a marine mechanic though, I mostly work on I/O's ( 305's, 350's, 454's.......) Mercruiser's. But I have done all the mods on my TL myself, I/H/E, gutted cat, changed ALL motor mounts, ignition switch.............I have a shop with all the tools needed so im going to look for that thread first then go for it........thanks.
Old Jun 3, 2008 | 10:14 AM
MurdaZ's Avatar
well if u can do the motor mounts u can do the timing belt... imo when i did mine, it was a pain in the ass...got the 120k service done at a local shop
Old Jun 3, 2008 | 12:15 PM
acutee's Avatar
Here is the link for timing belt from southern:
https://acurazine.com/forums/showthr...vice+completed
Old Jun 3, 2008 | 05:05 PM
if you can do it on the teg, you can do it on this. Have fun. Buy the crank pully tool, or you will be pissed, and have to go buy it once you fail to get the bolt loose.
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Skirmich
Sep 15, 2015 06:41 PM
forrie
Sep 15, 2015 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
ShyGuyMcFly83
ILX
Sep 11, 2015 10:51 PM
