s r s light
if you have done ANY electrical work or unplugged a seat or anything recently- then do the SRS system reset procedure and see if it comes back on
If it does proceed as below
If you have not touched the car electrical to cause a false code: call acura care and verify you are part of the SRS extended warranty to 10/150, call 1 800 382 2238x5
call dealer for `SRS light appointment`
there is a special warranty for a reason- failures!
they may have to get a sensor in the seat or other part, iirc it covers 5 of 6 parts in the system- those most likely to fail,, and approx 99 percent of the cars with SRS light fall under the warranty coverage
1 in 1000 have a different part fail thats not covered
good luck!!
good luck!!
The reason you will have to go to the dealer if the reset doesn't work is that diagnosis of SRS problems requires a special scanner (different from engine light scanner). If the problem is covered under warranty...great. If not, anyone can replace the necessary part(s), then you can reset yourself.
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
