RPM Bouncing
Old Dec 11, 2018 | 03:28 AM
jaaaydeeem's Avatar
RPM Bouncing
To shorten the backstory.. it's a similar case to a previous thread:
https://acurazine.com/forums/2g-tl-p...-today-921864/
CAI sucked up some water due to the rain. Not a ton of water but enough to cause it to misfire and started to see the same color distortion in the oil.(cream/yellow color). There was also the RPM bouncing between 1500-3000. Doesn't matter if I was in park or drive, the car seemed to want to accelerate on it's own...
Found two bad coils and one of the cylinders got oil in it. The O-ring was all melted. Took off the everything and replaced the gaskets on that rear valve, replaced that 1 spark plug and the two coils, did the seafoam and drained the rainy-oil. Put in 2.5 liters of oil cause i'm gonna do another drain and fill just in case. Got everything put back together but the RPM issue is still present.
Any idea what it is?? I'm thinking I should of replaced all 6 spark plugs.
Old Dec 11, 2018 | 05:51 AM
so modest...."not a lot of water but enough to cause problems" lol
regardless of the water mishap, a surging idle indicates a vacuum leak somewhere.
I would also perform a leak down and compression tests. these tests will show if your cylinders are all holding consistent pressure...and the leak down test will show if any air is escaping through the valves
Old Dec 12, 2018 | 03:28 AM
jaaaydeeem's Avatar
LOL. It's cause I was comparing what my oil looked like to the other thread. But I will look into the vacuum leak again, since i didn't find anything while I was putting everything back together. As far as leak down and compression test i'll have to look into that as well... jus gotta get the tools.
Thanks for the help!!
Acura11TL
4G TL Problems & Fixes
29
Sep 26, 2013 03:54 PM
David1221
Aug 26, 2013 07:45 PM
tigerpause444
Jan 24, 2012 03:34 AM
acurabum
Apr 30, 2009 12:30 AM
SirSpif
Jan 27, 2004 08:28 PM
