Rough Idle problem
Old Apr 21, 2013 | 06:30 PM
timmay anderson's Avatar
3rd Gear
Rough Idle problem
I have a rough Idle condition that I'm trying to figure out.Just looking for any help with this.The problem just started a couple of days ago.I only really feel it when in park.the car just doen't idle like it should.There are no check engine lights on yet>other than that it runs fine,in gear no problem ,driving is fine.I changed the plugs and it did not improve.Also replaced the Idle air controll,just for the hell off it.Did not help.Any input on the would be great.Thanks
Old Apr 21, 2013 | 09:11 PM
victus1's Avatar
A dirty/sticky EGR valve can cause idle problems. Easy to remove (2 bolts) and clean with carb cleaner. Use a flat screwdriver to lift the pin and spray lots of cleaner in there, let it sit and repeat until it flows out clear. You will also need a new gasket to reinstall.
Another area of concern is the build-up of carbon gunk in the intake manifold egr-flow ports. Easy job, but the cleaning is tedious. Search for the egr port cleaning diy here. You also need to run a coat hanger from the main port in the intake right thru to the base of the EGR valve to clean out the gunk.
Also a good idea to clean the throttle body and air plate with carb cleaner.
As for your IACV, you could have cleaned it with carb cleaner instead of buying a new one.
Old Apr 22, 2013 | 06:02 PM
3.2TLc's Avatar
Yeah, as Victus1 said.....do this, read the DIY's, and check back.
Old Apr 23, 2013 | 03:29 PM
WJO1994's Avatar
Will O.
Thanks!
Really helped me out, thanks guys.
Old Apr 23, 2013 | 03:43 PM
victus1's Avatar
Let us know how you fixed your problem. Thanks.
Old Apr 27, 2013 | 07:19 AM
3rd Gear
I did clean the egr valve.as well as the pcv valve,throttle body.Removed the intake , cleaned everything super good.did not change.still idleing bad,poop!thanks for all the help though!I'll keep trying for sure.stuff like this just pisses me off.
Old Apr 27, 2013 | 07:36 AM
3.2TLc's Avatar
Check all the vacuum and electrical connections/grounds. Run some fuel injector cleaner through the gas. Maybe have the fuel pressure checked.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
NSolace
Sep 3, 2015 08:14 PM
