Rotors???
Old Aug 26, 2007 | 05:56 PM
JoBiggs's Avatar
Rotors???
anyone know a trick to get the two larger bolts on the back of the calipers? Tried wd40 any help would be great
Old Aug 26, 2007 | 06:49 PM
01tl4tl's Avatar
The bolts that hold the bracket assembly to the car- those are on with 80 foot pounds torque- same as the wheels are supposed to be
Turn the wheel in the direction of the side you are on to expose the bolts
If fronts- put a 19 MM wrench on that inner nut you can just see the edge of, then push down on the ratchet/socket bar with your foot- should come loose then
Shoot lots of WD in the center hub- rust lives there and is very grippy
Good idea to bleed the brakes first to avoid backwashing crud into the system, causing caliper failure in a month
Old Aug 26, 2007 | 08:28 PM
JoBiggs's Avatar
thanks i'll try again
Old Aug 26, 2007 | 09:02 PM
fsttyms1's Avatar
Use a 1/2 inch wrench not a 3/8 if thats what your using
Old Aug 27, 2007 | 05:55 AM
JoBiggs's Avatar
They're really on there and seem like they won't budge...anymore suggestions before I decide to give up and go pay for it to be done?
Old Aug 27, 2007 | 11:34 AM
01tl4tl's Avatar
~Leverage~
Assuming you removed the 2 smaller bolts and the caliper and have it safely tied up to the strut with a wire-
I had mine off last night, slid a long square metal bar over the handle of the ratchet and that did it.
If a shop did yours last time, they are just on way to tight, and you may have to relent and let a shop do the job- or at least have them reset the torque to 80 so you can get them off yourself
Most techs blast them on with the air gun- so about 100+ ft lbs of torque
NOTE: Did you get the 2 screws on the rotor hub loose yet?
If not- just head to the shop now
Old Aug 29, 2007 | 05:38 PM
doubledeala's Avatar
impact out of the question?
Old Aug 31, 2007 | 10:58 AM
JoBiggs's Avatar
can the impact driver be used for bolts as well as screws?
Old Sep 1, 2007 | 12:15 AM
well yeah...same principle...
Old Sep 1, 2007 | 04:08 PM
Mike B's Avatar
Instead of WD40, use liquid wrench. Or use a wrench with a another wrench to achieve more leverage.
Old Sep 1, 2007 | 05:11 PM
JoBiggs's Avatar
thanks
Old Sep 1, 2007 | 06:06 PM
01tl4tl's Avatar
Had one stuck the other day- used the wrench on a wrench- no luck
put the handle from the floor jack over the ratchet handle and 4 foot leverage took it right off!
Someone used and impact air gun to install with no concern last time!
Liquid wrench good stuff- I just figure everyone has a can of wd, and anything helps in a pinch
Old Sep 2, 2007 | 07:21 AM
Ellcapitan's Avatar
Be careful with penetrating oil around the wheel bearing. Having said that, soak the bolts for like a half hour, then get a blow torch, and EVENLY heat up the surrounding metal (again, stay away from them bearings). Then try again with a 6-point closed-end wrench (a 12-point might damage the bolts). If that still dont work, go to an impact driver. Don't stand, and bounce on the wrench; you WILL break a bolt head! Either way, once you get them out, replace the bolts with new ones (and use anti-sieze on them this time).
Old Sep 2, 2007 | 09:04 AM
chhimp's Avatar
how about an extension, breaker bar for leverage.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
