replacing rear calipers today, is there a write-up to follow?
Old Dec 17, 2006 | 09:12 AM
payyourtoll's Avatar
our 99 3.2TL rear calipers have finally seized (rubber seals were damaged a while back and just waited them out). I have a pair of remanufactured calipers, but I was wondering if there is a DIY to follow? I can turn a wrench but never replaced calipers before. Thanks for any help
Rob
Old Dec 17, 2006 | 09:51 AM
dunlax072's Avatar
http://www.cardomain.com/ride/184466/23
Old Dec 17, 2006 | 12:21 PM
fsttyms1's Avatar
Nothing hard to doing in, basically remove the brake line, remove the 2 bolts holding it on. . You will have to bleed the brakes afterwards though.
Old Dec 18, 2006 | 09:31 PM
01tl4tl's Avatar
Stick a rubber vacuum cap over the open brake line (after you unsrew it from the caliper)- this will keep more fluid in the line and less on your floor. See main 2ndg gen forum page for rear brake tips I posted yesterday, a big mallet will help!
Old Dec 24, 2006 | 09:30 PM
01tl4tl's Avatar
Hey payyourtoll
How did the rear caliper replace go? Any tips or problems to pass on to other members of the group? How was bleeding the brakes- etc
Old Jan 8, 2007 | 08:23 AM
hey, sorry for the late reply, I did not get an email notification about a reply..
The two main bolts holding the caliper to the frame were a little tought to get out. Just make sure to have a can of PB Blaster and a hammer on hand to knock the bolts loose. The rest is simple, just have someone help in bleeding the brakes out when they are back together. Overall it was about 30 minutes a side
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
