Replacing headlights
I have a '03 tl-s and Im replacing both of my headlights, original ballast, but new bulbs. I wanted to hear some best practices and faster ways to execute.
Thank you
Mike
Thank you
Mike
02 Acura TL headlight replacement
New here - I have a 2002 Acura TL with 85,000 Km Just noticed that both headlights have condensation in them. I bought new headlights and attempted to replace them. After attempting to do this myself I gave up. Does anyone have any specific step by step instructions hopefully with pictures, on how to replace both headlights?
After searching the net a bit more I found the answer to my question. Below is the link that shows you how to do it.
http://www.cardomain.com/ride/184466/18
need help on new HID color
I have a 2001 TL stock HID i just want to replace both beacuse one of them is turning, well it looks purple than the other one. I want them to be blue but something were I an see at night as well?
To mikeaveli: its really easy if you've got the patience. First reomove the bulb housings. On my '99 there are tamper proof screws on the top side of the housing. If you have the tamper proof bit, cool. If not I used some needle nose pliers to get mine off. Next unscrew the housings. The drivers side is a little tricky. There's a limited amount of space there. You will want to remove the radiator overflow bottle and sit it to the side. The next part is fun! There is a clip on each bulb. You do not need to remove the screws holding it like I did. You want to push down on the bottom of it and push it sideways to free it from the hook that its holding on to. You will know when its free. Voila! Take out the old and replace it with the new one. The bulb fits in a certain way. Spin it till it lines up. Make sure the new bulbs go back in their socket correctly also. Put everything back and you're done!
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
