replacing door actuator!?
Old Nov 1, 2009 | 08:45 PM
JterrorC's Avatar
Always a Honda =Þ
ok so i bought the car with this noise thinkin nothing of it...easy fix...but i never got to do it....
FINALLY....door panel off....actuator is in a deep damn uncofortable corner.....no idea how to take if off...HELP!!
som pics n a vid of the gears slipping...well hopefully jus that
rear right door its located right under the door handle
another view
this is the good rear left dr actuator for a 98 accord....dont wry..i know its opposite....but im jus switching the gears...
http://www.youtube.com/watch?v=FLrx0ROMR4E
Old Nov 1, 2009 | 09:11 PM
JterrorC's Avatar
Always a Honda =Þ
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-actuator-replacement-w-o-removing-anything-inside-704477/
i found this..but not helping me..mayb cuz its nite time...illl work on it tom morn...
Old Nov 1, 2009 | 10:01 PM
juanclopez2786's Avatar
wuts ur email?
Old Nov 1, 2009 | 10:10 PM
friesm2000's Avatar
B A N N E D
can't see anything really during the video , and i just hear a car revving, but look along where the door seal runs in the door jamb are and the door latch is, there should be two srcews (might be torx though), undoing those will loosen the door latch/lock
Old Nov 2, 2009 | 06:25 PM
nhn23's Avatar
I live in
i dont know the answe to your problem but your "locked" beep sounds pretty loud as to mine..maybe its the vid?
Old Nov 2, 2009 | 06:49 PM
my.daily'tl''s Avatar
Always Working In
The screws aren't torx. Regular philips. If I remember right its two or three holding it in the door and then the arm for the latch. Rears are a little bit harder than the fronts because they're set in the doors so far. Wish I could give you some good instructions, just take your time. It will also help to have a long shank screwdriver to help you. Just have a little patience, good luck!
Old Nov 2, 2009 | 09:16 PM
JterrorC's Avatar
Always a Honda =Þ
yea after i unscrew the door lock is came right out..i thought i could do it without taking that out...but u cant
Old Nov 2, 2009 | 09:18 PM
did u fix it?
Old Nov 9, 2009 | 12:22 AM
JterrorC's Avatar
Always a Honda =Þ
nah..i got everything out...but da gear i had was GR4....n i needed GL4...sob....i had a right door not a left door..didnt think it matter....
ohwell...it only cost me 10...still hav the noise..
now my window stuck tho....wth!...what could i hav done
Old Nov 9, 2009 | 06:20 AM
check the track for the window. theres a bar u gotta take out to get to the actuator.
Old Nov 12, 2009 | 09:55 PM
JterrorC's Avatar
Always a Honda =Þ
oooo shyt yea...i didnt put the screw back..whoops...
Old Aug 4, 2010 | 10:39 AM
3xTRANNY's Avatar
3rd Gear
I have a similar problem, but its the front passenger door, removed panel, removes plastic sound dampening material, took out the actuator but, I cannot get the new one properly, there is a small pole that has to inserted through the actuator arm. any ideas on how this works
Old Aug 5, 2010 | 10:11 AM
smartypants's Avatar
Hi All :
Sorry Jt if I semi-hijack your thread......
I have a intermittent front passenger side lock actuator that I can't seem to remove. I can get all the fasteners off and the unit is free in the door but I can't seem to maneuver the unit out from behind the window track. Looking at the parts catalog, I have a sneaky suspicion that the unit splits into two pieces and that's how you get it (them) out.
Can anyone confirm this is how to remove the unit (s) and also, which of the two pieces is the one that usually fails ?
Thanks in advance.
smartypants
Old Aug 6, 2010 | 05:53 AM
Always Working In
No the actuator does not come in two pieces. The moving part (the arm) is what usually gets stuck after you remove the three screws. Its just a feel by hand process at this time. I haven't seen a doy on this.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
