replacing door actuator!?
ok so i bought the car with this noise thinkin nothing of it...easy fix...but i never got to do it....
FINALLY....door panel off....actuator is in a deep damn uncofortable corner.....no idea how to take if off...HELP!!
som pics n a vid of the gears slipping...well hopefully jus that
rear right door its located right under the door handle
another view
this is the good rear left dr actuator for a 98 accord....dont wry..i know its opposite....but im jus switching the gears...
http://www.youtube.com/watch?v=FLrx0ROMR4E
another view
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-door-actuator-replacement-w-o-removing-anything-inside-704477/
i found this..but not helping me..mayb cuz its nite time...illl work on it tom morn...
Always Working In
The screws aren't torx. Regular philips. If I remember right its two or three holding it in the door and then the arm for the latch. Rears are a little bit harder than the fronts because they're set in the doors so far. Wish I could give you some good instructions, just take your time. It will also help to have a long shank screwdriver to help you. Just have a little patience, good luck!
I have a similar problem, but its the front passenger door, removed panel, removes plastic sound dampening material, took out the actuator but, I cannot get the new one properly, there is a small pole that has to inserted through the actuator arm. any ideas on how this works
Hi All :
Sorry Jt if I semi-hijack your thread......
I have a intermittent front passenger side lock actuator that I can't seem to remove. I can get all the fasteners off and the unit is free in the door but I can't seem to maneuver the unit out from behind the window track. Looking at the parts catalog, I have a sneaky suspicion that the unit splits into two pieces and that's how you get it (them) out.
Can anyone confirm this is how to remove the unit (s) and also, which of the two pieces is the one that usually fails ?
Thanks in advance.
smartypants
Thanks in advance.
smartypants
Always Working In
No the actuator does not come in two pieces. The moving part (the arm) is what usually gets stuck after you remove the three screws. Its just a feel by hand process at this time. I haven't seen a doy on this.
rockyboy
12-06-2022 02:29 PM
tman570
06-11-2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
