replaced power steering pump
Old Apr 11, 2013 | 11:24 PM
twill220's Avatar
well i've replaced the p/s pump with a used one and still have that annoying whine coming from the pump. this used pump had less than 80k miles on it and i still have that loud whining noise coming from the pump. any suggestions would be greatly welcomed
Old Apr 11, 2013 | 11:31 PM
ErickUa5's Avatar
Mr.Helpful Diagram
check the hose that goes from the reservoir to the pump if its hard or brittle replace it or cut a new end, Does it do it only when cold ?
Old Apr 12, 2013 | 06:52 AM
fsttyms1's Avatar
Buy the new o rings for the pump, Take the pump back out and install them. Over tightening the belt will cause this to happen pretty easy
Old Apr 14, 2013 | 07:08 AM
twill220's Avatar
finally... no more whining from p/s pump
the o-ring did the trick... no more whining from p/s pump. thanks to the acurazine family for helping me solve this problem
Old Apr 15, 2013 | 06:54 AM
3.2TLc's Avatar
Hey Twill220, So you replaced your original PS pump with another used one that also whined.
Just curious, had you tried putting the new o-rings on the old one before swapping it ?
Old Apr 15, 2013 | 07:27 AM
twill220's Avatar
finally...
yes i did try to rebuild the original pump, bought the repair kit that came with o-rings and a seal. however, i ran into some trouble trying to get the locking pin back in. so i bought the used one and installed it. it still whined, so i replaced the o-ring where the res. hose goes to pump. prior to that, the pressure hose from p/s was leaking and had to be replaced...napa n autozone wanted 200, found it at rockauto for 93 including shipping. took me awhile to finally have it fixed the right way because i'm having back problems. but thanks again to the acurazine family....
Old Apr 15, 2013 | 07:48 AM
3.2TLc's Avatar
Yeah, replacing the hose probably took a toll on ya. Good to hear ya got it fixed, sure hope you're feeling better when the next DIY opportunity comes knocking. Definitely a challenge, but saving some bucks and the satisfaction of resolving it yourself helps lessen the pain !
Old Apr 16, 2013 | 01:25 PM
David1221's Avatar
I need to replace my Oring also, but it looks like a pain to get off. Is a swivel socket the best way to get to that little bolt?
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
spidermankb
Mar 5, 2019 11:34 AM
mike from annapolis
May 7, 2017 08:21 PM
asahrts
Sep 4, 2015 05:55 PM
