Replaced CV joint, Car wont start
Old Jan 31, 2012 | 08:06 PM
Calvin11's Avatar
Angry Replaced CV joint, Car wont start
Hey guys, okay so earlier today i replaced the CV joints on my 2000 Acura TL. The right one went fine, got it installed and everything, took it for a test drive and all was good. When it got to the left side, we still got it in and out okay and went to take it for a drive. Except the only problem is that when we tried to start the car, it sounded like it was trying to start and just died. So now the car wont start and it wont shift out of gear. We took the whole axel out and re-installed it, checking for any errors or damages, none. Still the same. So we re-installed the old axel to see if it made a difference. But it still doesnt turn on or wont shift out of Park.
You cant even hear the shift solenoid move. I can bypass this by using the neutral safety switch but the car doesnt start so all i can do is push it. We checked the brake light switch, most relays and am checking the PCM box that the solenoid wire runs to.
Anybody have any ideas? This day has been frustrating as hell..
Old Jan 31, 2012 | 08:08 PM
yeedatoy's Avatar
kill you till you die
It wont shift when you stick the key in the shift lock?
Old Jan 31, 2012 | 08:10 PM
Calvin11's Avatar
If you are referring to the thing to the right of the shift pad. Yes it does shift out of park using the bypass. But it doesnt really make a difference because i cant start the car
Old Jan 31, 2012 | 08:14 PM
yeedatoy's Avatar
I didn't think the car would shift out of park unless its running. The car wont jump start?
Old Jan 31, 2012 | 08:17 PM
Calvin11's Avatar
If you have the car in the "ON" position in the ignition it still moves. Tried it in the CL we have also, does the same thing, so its normal. Tried to jump start the car also, didnt make a difference, ..
Old Jan 31, 2012 | 08:22 PM
yeedatoy's Avatar
Weird, I cant see how the two would be related.
Old Jan 31, 2012 | 08:24 PM
yeedatoy's Avatar
What do you mean by "it just died"? What exactly happens when you turn the key? Does your immobilizer light flash?
Calvin11's Avatar
Yeah man, it just doesnt make sense.. so frustrating
Old Jan 31, 2012 | 08:32 PM
Calvin11's Avatar
I mean like you heard a click like it was about to start, then the click just died and now theres no sound at all. The engine doesnt even turn over, its like im not even turning the key at all. The guages fill up like normal and the lights come on as usual in the "ON" position. But after that nothing, no sound, nothing flashes.
Old Jan 31, 2012 | 08:48 PM
yeedatoy's Avatar
I wonder if your ignition switch interlock is bad...if you whack the steering wheel a few times or release the tilt lock and move the wheel up and down will it start?
Old Jan 31, 2012 | 08:58 PM
yeedatoy's Avatar
I know you said you checked the brake light switch, how did you check it? Brake lights work fine? I don't know what the hell it could be beside that switch, thats really what it sounds like the issue is. Hope you get her going.
Old Feb 1, 2012 | 11:20 AM
StreetKA's Avatar
Is it turning at all ? Check maybe you knocked off the ground wire from the starter...
Old Feb 1, 2012 | 04:17 PM
Calvin11's Avatar
Yeah i kind of wish i knocked it off, check this out..
I coudnt believe how corroded it was. We found it by tracing the ground wire back from the transmission. But now everything is back together and the car runs. The D5 light was flashing but then realized we didnt hook something back up in the PCM..thank god not another transmission.
Attached Thumbnails Replaced CV joint, Car wont start-corroded-groundwire.jpg
Old Feb 1, 2012 | 05:58 PM
watsonauto's Avatar
3rd Gear
Im glad u found the problem-I work on hondas and acura (sorry just read post ) I no how frustrating it can be win its not even related
Old Feb 1, 2012 | 10:08 PM
Calvin11's Avatar
Thanks man, but oh yeah, me and my dad had a hell of a time.. at least changing the axel was fine
Old Feb 5, 2012 | 09:33 AM
jpadilla's Avatar
i was replacing a bottom ball joint boot and axle accidently popped out of the transmission while trying to slip the ball joint stud out of the lower control arm. Scared as crap now. How the hell do i pop it back in? Do I have to take the whole nuckle apart?
I can't even put this back together to roll it out of the garage onto a tow truck to take to the dealer.
By the way, all I did was remove the pin and bolt for the lower ball joint and remote the bolt for the lower control arm and fork. maybe that is why the axle popped out.
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
voigt
Sep 2, 2015 10:44 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
