Replace TPS and/or MAP sensor???
Old Sep 14, 2019 | 04:22 AM
TL_2gen13's Avatar
9th Gear
Hey acurazine..recently I took my intake manifold off and did a super clean. I mean i took everything apart. Now about a week later I was on the freeway just cruising then an integra blows by me. So I smash on the pedal like I usually do on the freeway. Then my TCS light came on as well as my CEL. I borrowed my friends basic code reader and found a misfire in cylinder 3 and 4. And a random misfire. Then cleared the codes and checked my spark plugs and coil packs and everything seems up to par.. so then a couple days later same thing basically happen. On freeway smashed gas and it happened again... it's only when I smash and get my rpms close 2 redline that this happens..cruising around city no light flashes or tuns on..even when I'm creep up to 100+ mph I don't get no light or nothin. Car drives like normal. Rpms at stable at 750...after the 2nd time.. I called my friend up with a bit more advanced scanner and I got the complete system scanned and it came up with 4 different codes that the other scanner didn't show at all.. how I've been doin slot of research on tps sensors and its purpose and also map sensors. I jus ordered the tps sensor from powerrevracing today.. now I'm gonna get the map sensor next. Wheres a good place to buy those at? And does Anybody know why I only get a blinking or solid CEL when I am at WOT and almost redlining??? Besides it bein a bad sensor. It's on a 03 tl-p. Both are original sensors from factory back in 02.
Old Jul 20, 2022 | 07:03 PM
hellgirl117's Avatar
Did you ever figure out what happened and how to fix it? I have those exact same codes
pattiger69
Aug 21, 2014 10:47 AM
main70072
1G TL Problems & Fixes
Jun 21, 2013 10:48 PM
99vtecaccord
Jun 11, 2013 05:47 PM
Soccer_playa1579
Sep 16, 2012 10:49 AM
Adrenalin540
Sep 2, 2008 01:31 PM
