Replace TB gasket when cleaning EGR?
Old Mar 27, 2007 | 02:50 PM
slowboat's Avatar
Hey fellas. I'm gearing up to pull the intake manifold on my '99 TL to clean the EGR ports.
The instructions in the Acura bulletin say to replace the throttle body gasket. I've read the many DIY instructions on this board and no one has mentioned replacing it.
I know it's a cheap part-- I'm just trying to avoid a trip to my stealer if I can.
Old Mar 27, 2007 | 03:16 PM
01tl4tl's Avatar
Pick one up while you are out buying some Throttle Body Cleaner $3-5- not same as carb clean
Spray liberally as directed
Better safe than a manifold vac leak
Old Mar 27, 2007 | 06:12 PM
fsttyms1's Avatar
There is no need for removing the TB when just cleaning. . Keep it attached
Old Mar 27, 2007 | 06:28 PM
HockyStar89's Avatar
anyone know the DIY thread on doing this?? id like to check it out
Old Mar 27, 2007 | 08:15 PM
orgnlprankster7's Avatar
08 Civic SI
actualy im going to write one up in a day or 2 when my spacers come, i just cleaned my egr and manifold 2 days ago, but im going to take pics when i install the spacers. fyi i didnt remove the throttle body when i cleaned it. its not nearly as hard as i thought
Old Mar 27, 2007 | 09:00 PM
fsttyms1's Avatar
do a search for EGR Cleaning. The DIYs are out there. It also depends on what year you have. The 99 is different from the 2000-2003
Old Mar 27, 2007 | 10:41 PM
k well if anyone can post a DIY for a 99 or even the difference between would be huge
Old Mar 27, 2007 | 11:52 PM
08 Civic SI
the one ill be doing is for a 99, give me a day or 2
Old Mar 28, 2007 | 09:41 AM
fsttyms1's Avatar
Ok ill bite. ill do all the work for you. Like i said, use the search button. the DIYs are already out there. (also found in the DIY mod section)
http://www.in.honda.com/Rjanisis/pubs/SB/B00-004.PDF
00+
https://acurazine.com/forums/showpos...39&postcount=8
DIY Section
https://acurazine.com/forums/ramblings-12/sex-jokes-142016/
Old Mar 28, 2007 | 11:53 AM
Eisenhulk's Avatar
MUCH bigger than you!!
Kris,
Question. What if I have already replaced the EGR valve, cleaned the intake and I'm still getting the Insufficient EGR flow code? What else could be done?
EH
00+
DIY Section
https://acurazine.com/forums/showthread.php?t=142016
Old Mar 28, 2007 | 12:32 PM
fsttyms1's Avatar
when you cleaned it did you take the upper intake manifold off to clean it out? did you clean all the little tracks in the upper cover, and did you clean out the lower intake manifold to egr hole?
Old Mar 28, 2007 | 02:41 PM
Eisenhulk's Avatar
Yes, yes and yes.
Granted I did all of that six months ago, and I replaced the EGR three weeks ago. But since I gave all you mentioned a great cleaning, I didn't bother when replacing the EGR.
You're probably going to tell me that I need to clean all of that again, right?
Old Mar 29, 2007 | 08:10 AM
08 Civic SI
how would u go about cleaning the lower IM egr hole. it was dirty also but i idnt want to spray anything into it or the lower IM
Old Mar 29, 2007 | 10:02 AM
fsttyms1's Avatar
Originally Posted by Eisenhulk
Yes, yes and yes.
something is still dirty causing it. Thats the only thing it can be
With the upper IM look into the port to see if its dirty/clogged. If it is you can use a small pope cleaner brush and some cleaner. Take the EGR off before doing so.
Old Mar 29, 2007 | 10:07 AM
Eisenhulk's Avatar
Thought so. I'll get to that in the next couple of weeks. Thanks, Kris.
Old Mar 29, 2007 | 10:29 AM
08 Civic SI
*EDIT* how do i got about cleaning this egr hole, theres a buncha shit stuck in there
i dont want the crap falling into the hole
Old Mar 29, 2007 | 02:42 PM
Sust Man's Avatar
I never replaced mine, but I know the Oreilly by my house had them for like 5 bucks. I would buy one just in case it is in bad shape by the time you take it off. I just didn't feel like driving there. The autozone near me didn't have one but could order it. You don't need to go to the dealer.
Old Mar 29, 2007 | 02:47 PM
fsttyms1's Avatar
Scrub brush, compressed air/shopvac. thats why i recommended taking off the egr as well.
Old Mar 30, 2007 | 08:03 AM
Eisenhulk's Avatar
Kris,
Aside from the insufficient EGR flow, I'm also getting the following code: P1457 Manufacturer Contrl. Auxiliary emission controls
Any idea as to what can cause this and how to fix it?
Old Apr 2, 2007 | 05:45 PM
Eisenhulk's Avatar
BUMP.
Comments please.
QUOTE=Eisenhulk]Kris,
Any idea as to what can cause this and how to fix it?[/QUOTE]
Old Apr 2, 2007 | 09:34 PM
Sust Man's Avatar
I was kinda curious, so I googled it. This may be what your looking for.
http://www.honda-acura.net/forums/sh...03#post1486403
Old Apr 2, 2007 | 11:35 PM
Eisenhulk's Avatar
Thanks, bro. I really do appreciate you finding that.
Old Apr 3, 2007 | 09:42 AM
fsttyms1's Avatar
Beat me to it. There are many things to try. I would use the link to try what was mentioned. But i would do it only after you have cleaned teh egr ports so that its not causing a code
Old Apr 3, 2007 | 09:52 AM
Eisenhulk's Avatar
Thanks, Kris. It has been throwing both the insufficient EGR flow and evap canister code for a long time now...and I can't see to get rid of it.
Some of the procedures mentioned in that link are a little unfamiliar to me...Any pointers?
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
ibGTV
Sep 28, 2015 03:40 AM
asahrts
Sep 4, 2015 05:55 PM
