Removing A Terminal From The Connector
Old Mar 12, 2011 | 03:05 PM
tcha143's Avatar
4th Gear
Hey everyone,
How do you remove a terminal from a connector? I'm trying to replace the harness from the blower motor in my 2001 acura TL. I have to get a yellow and black terminal out of the brown c202 connector but I can't seem to find a release mechanism. It does have a white tab at the top that partially slides out but from that point on I'm stuck.
Thanks In Advance
Old Mar 12, 2011 | 05:00 PM
01tl4tl's Avatar
without looking at mine to be sure:
ck for a way to slide a small screwdriver type tip into the back side of the assembly-often a release hook on the wire connector there
ck diy section--have we added cabin fan prob to it?
Old Mar 12, 2011 | 11:01 PM
totaledTL's Avatar
Get a magnifier & look closely at the inside, both ends. There's probably a "tang" that's holding ea. terminal in that has to be pushed back straight to release the terminal from the body. You may have to push the wire in slightly first. That's the best way I know to describe it w/out looking at the specific connector.
Look here http://www.ff-squad.com/tech/wiring/...in_removal.jpg
& here http://members.shaw.ca/FifthGenTSB1/...eplacement.pdf
Hope that helps.
Old Mar 18, 2011 | 02:09 AM
acuratech1's Avatar
well the ghetto way would be to smash it with something but there actually is a small terminal tool for this sort of thing...but if not avaliable use a small screw driver and depending on the connector you usually push up or down on the small tab to relase the pin...also on the wire side there might be 2 small clips the length of the connector that must be removed
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
iesu3423
Sep 29, 2015 08:04 AM
polish_pat
Sep 25, 2015 12:24 PM
