Removing From Park/Radio
Old Sep 19, 2007 | 01:22 AM
BonesyJonesy's Avatar
Ok, first let me say I am not mechanically inclined what-so-ever. I have no idea what is going on w/my 03 TL-Type S. I've only owned the car for about 4 months. Occasionally (once every 3-4 weeks), my car would go into what I call "theft-mode". By this I mean, it would not allow me to remove the gear shift from park, the power to the radio/power outlet does not exist, and the anti-theft light in the lower right hand corner continues to blink almost as to say "HAHAHAHAHA". I then called the Acura dealer to find out that they will charge me a nice $100 to run a diagnostic test on it, or I can just use the "trip" next to the gear shifter inorder to remove my car from park and live w/out the radio. Does anyone have any idea what might be going on??? It's almost as though the car doesn't read the key as an actual key. Thank you in advance to any help you guys might have!!!
Old Sep 19, 2007 | 01:42 AM
01tl4tl's Avatar
most likely its the brake light switch - do your brake lights work?
its an easy cheap fix with a part that bolts on under the brake pedal- its a safety interlock, the little thing you are pushing next to the gearshift is the nuetral safety switch- it prevents you from trying to start the car in drive and is the emergency release if the brake switch dies
Take it to a private shop for these- very easy to diagnose and repair
the fee is to protect them from spending an hour figuring out the problem then you take it home and fix- if you have the work done there its included - no worries
Old Sep 19, 2007 | 08:29 AM
fsttyms1's Avatar
i would almost have to say something else isnt right since the radio isnt coming on as well.
Old Mar 18, 2010 | 12:57 PM
dc2kid's Avatar
i have the same problem did you figure it out?
Old Mar 19, 2010 | 09:08 AM
gold2003tl (90)'s Avatar
2003 TL-p
sounds like an electrical problem, im guessing a loose wire or connection.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
