recall 03 tl type s tran
My name is roland we have a 2003 tl type s VIN # 19UUA56943A001864 The trans has slipped since 20012 and finally the thing slipped inbetween gears and messed up ingine how do i find out recall info or am i SOL if so can i replace it with a 6 speed standard .
the recall issued back in 2003? was to install an external oil jet kit in the filler hole for trans
Does your car have a large bolt with ATF stamped on it? or it has a small oil line going to a special fixture inserted into atf filler hole- top center of trans?
Next- are there any bolts on your trans that hold things to trans (ie: brackets)
or main trans to engine bolts - with BLUE paint on the bolt heads??
= that's a warranty replaced transmission- usually because of the court ordered 109kmiles trans warranty on the clutch wearout problem
that ended at 7 years of cars age
A slipping trans should not damage the engine!!! the rev limiter is your friend in this case
End result : its time to read the 6 speed swap thread
If the engine is truly hurt- you can drop in an complete used CL-S motor and 6speed- as our master modder and moderator fsttyms1 has
see threads near top of list for his projects
What makes you think the engine is hurt now?
justin7779
12-25-2015 10:33 PM
mugen_kid
11-13-2015 10:38 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
