Rear Rotors
Old Jun 25, 2009 | 03:25 PM
MurdaZ's Avatar
Rear Rotors
how can i tell if a rear rotor is warped?
if i press the brake pedal, and my brake pedal, seat/back rest shakes, and the steering wheel barely shakes, indicates a warped rear rotor?
Old Jun 25, 2009 | 05:57 PM
twistedwedge's Avatar
6MT Someday..
usually if your rears are warped you will feel it in the seat of your pants..like you said, steering wheel is normally fronts.
Old Jun 25, 2009 | 06:15 PM
TLin401's Avatar
'13 Hyundai Sonata
If your rotors are warped you will feel it also when you stop. I compare it to going down to different levels before you come to a complete stop.
Old Jun 25, 2009 | 10:57 PM
juanclopez2786's Avatar
usually u feel warped rotors for the rear in the brake pedal and warped rotors in the front in the steering wheel.
Old Jun 26, 2009 | 12:15 AM
woot427's Avatar
^ makes sense...when i press on brakes, i feel a pulsation/vibration ...but its not all the time tho, but it looks like it leading to signs of warped rear rotors :-(
by feeling fronts thru steeering wheel, what do u mean? shaking of the steering wheel when braking?
Old Jun 26, 2009 | 07:04 AM
MurdaZ's Avatar
^^ yes the steering wheel will shake left/right pretty much the same as a bad balanced wheel. but with the warped front it usualyl shakes faster the harder u press it/going from a faster speed.
thanks guys...guess i went to aggresive with oem rotors and ebc greenstuff lol..
Aug 15, 2019 12:58 PM
yesSIR-S
May 13, 2016 05:42 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
