really stiff gas pedal, how to fix?
Old May 8, 2008 | 06:57 PM
xlingstax's Avatar
hi guys, i been noticing that when i step on the gas, the pedal feels really stiff, likes its locked or something, and i gotta step down kinda extra hard just for it to go down. is there any way to fix this? i dont really know much about cars.
and no, there isnt a squishy ball or something under the pedal >_<
thanks in advance
Old May 8, 2008 | 07:48 PM
01tl4tl's Avatar
remove the plastic engine cover- 4-10mm bolts, and check the throttle cable assembly for interferance or just plain out of grease to allow easy movement
Get another ziner to help remove and lube the cable at the throttle and reassemble
Old May 8, 2008 | 08:04 PM
co1063's Avatar
mine is out of grease, i can feel it, but i cannot get the bolts out of the cover, seems like they are rusted on, i tried soaking in WD40. any suggestions?
Old May 8, 2008 | 08:11 PM
01tl4tl's Avatar
bust them off- and throw the plastic engine cover in the garage pile- no kidding~
they are small 10mm head bolts- not on supertight normally
make sure we are talking about the same bolts before breaking them!
Old May 8, 2008 | 08:42 PM
co1063's Avatar
which tool do you recommend?
Old May 8, 2008 | 09:21 PM
fsttyms1's Avatar
A socket wrench with a 10mm socket and some elbow grease.
Check that the TB is clean and carbon free as it will cause it to stick early on as well
rockyboy
Aug 4, 2024 10:35 AM
peti1212
ILX
Sep 22, 2015 11:11 AM
04tler
Sep 10, 2015 01:13 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
