Random misfire code p1399
Old May 3, 2023 | 04:58 PM
Keith johnson's Avatar
Can anyone help I am having a misfire problem on my 01 acura tl, I kept getting misfire code p1399 but the car is not misfiring I got valve adjustment done I changed all the plugs and coil, I have no vacuum leaks but this code won't go away the car has only 176k miles does anyone ever experience this problem before and how did they fix this problem thanks if anyone have any solution to this issue
Old May 3, 2023 | 07:40 PM
Ron A's Avatar
Administrator
The forum where you originally posted, the AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
This was explained in the sticky thread at the top of that forum, or click here if you can't find it, which will explain why you shouldn't have posted your thread there.
Old May 4, 2023 | 11:45 AM
whitetiger5's Avatar
  • Were there any other DTC's?
  • Which brand coils did you replace it with?
  • Did you read page 11-118 in the service manual? it describes different scenarios that would trigger the misfire, can you comment on anything there?
Old May 4, 2023 | 12:21 PM
Thanks whitetiger for your quick response, I do not have a service manual but there are few other things I got done on the engine I had the valves adjusted, the coils I am using or ngk I had the egr valve port clean there is no other dtc on the car also the car is not misfiring the code just keeps popping up on the scanner for example when I clear the check engine light and starts the car the check engine light won't pop up until the car starts the second time
Old May 4, 2023 | 03:41 PM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
Just to clarify, did you have the P1399 before the valve adjustment, plugs and coil change or did it pop up after?
What specific spark plugs did you get?
Do you have a code scanner with "freeze frame"? It will tell you the conditions when the code was triggered.
Old May 4, 2023 | 04:37 PM
I did the valve adjustment after the code came up the plugs and coil are all ngk ok I will check the free frame and see what's going on
Old May 7, 2023 | 07:44 PM
Jon M's Avatar
to start here is a link to the manual.
Tim-tl
Mar 29, 2023 08:32 AM
RockAuto
Sponsored Sales & Group Buys
Feb 21, 2021 10:17 AM
Joe James
New Member Introductions
Aug 16, 2017 08:22 AM
