Radio won't reset with correct code after battery disconnect
Old Dec 12, 2010 | 06:40 PM
gheacock's Avatar
Acura TL, 2002:
I changed the battery but couldn't reset the radio with the security code I had from when I bought the car. I read that there could be interference from the antenna and some one had suggested disconnecting the antenna as a solution, then enter the code. This was cumbersome and I could not remove all of the trim to get to the back of the radio. I read that some one drove down to an underground garage to get rid of all radio signals and then entered the code and it worked.
I was very skeptical, but had nothing to lose. I drove down to the 2nd underground level of our local hospital's parking garage and then entered the code. IT WORKED!
I don't know why it works, but if you're having this problem with an Acura, it definitely works. And, as long as you can get underground away from radio signals, it really works.
Hope this helps some one fix their radio.
Old Dec 12, 2010 | 07:15 PM
01tl4tl's Avatar
welcome to the forum
you will find all the radio tips in the DIY section
the underground parking is a great trick~
Old Dec 12, 2010 | 08:52 PM
totaledTL's Avatar
Don't see any radio tips there-
There is a link in there that describes how to remove the trim & console to get to the radio.
Old Dec 13, 2010 | 11:36 AM
01tl4tl's Avatar
really? I know there is a section full of radio code tricks somewhere,,hmmmm
Old Dec 23, 2010 | 12:46 AM
Micheeellee's Avatar
Guess what! I went down a parking structure and i tried the radio code and it actually worked.
Old Dec 23, 2010 | 01:36 AM
xtremex626's Avatar
Regional Coordinator (SoCal)
^ lucky you. everytime my radio askes for a code, i always gotta take everything apart and disconnect the antenna from the back, reconnect, and put everything back together! such a hassle and you lose all your memory seat and mirror positions!
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
Stu2414
Aug 30, 2015 07:30 PM
