Radiator gauge
Old Feb 15, 2011 | 07:20 PM
E's00TL's Avatar
8th Gear
Radiator gauge
Hey Guys,
my radiator gauge is fluctuating. it got real close to "hot" today and i am worried. should i put coolant in?
thanks
E
Old Feb 15, 2011 | 09:46 PM
totaledTL's Avatar
Did you check the coolant level? Check w/ engine COLD- to radiator neck, also check the resv. The proper level is marked on it. Check that the hose inside is connected.
Any visible leakage under the car, in engine bay, etc.? How does the oil look? Do not drive it until you find out what the problem is. Overheating can cause serious (read- expensive $$) damage.
Old Feb 16, 2011 | 02:50 AM
01tl4tl's Avatar
all of the above!!
the TL never runs past half unless a serious problem- being bad water pump, bad fan sensor not turning on, stuck thermostat etc
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 21, 2015 08:51 AM
