programming remote
programming remote
Hello, can anyone help me with directions for programming a new remote. My old one broke and I purchased one on ebay. Thank you in advance for your help with this question.
mark
mark
Keyless entry Remote can be program by doing the following, you must program all remotes at the same time, else the remotes not included in the programming will not work.
Make sure the codes in the back of the new remote matches your old stock remote. Some key fob may look the same but won't work with each other. Be sure to have all Key fobs you want working with you when you do this.
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock button.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock button.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock button.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stores. Make sure you program all transmitters you want working within 10 seconds of each other. Ones not included in this programming will no longer work.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
***make sure the serial number on the backs match.....Program at your own risk***
and im assuming it doesnt matter if you sit in the car and do this right? i was sitting in there with the doors locked trying to point towards the glove box. lmk if i am doing something wrong before i give it another shot.
taking battery out, erases it all. so yes you need to reprogram it.
programming is a very fast step
have the remote in one hand, the key in the other
put it ignition
dont TURN ON THE CAR
just turn on the ac, ( how you would listen to radio roll windows down and such)
basically it will take a few steps to get it right
you have to do it very fast
turn up
press button
turn down
press button
turn up
press button
turn down press button
once you hear your car BEEP
take the key out
and try to lock the doors while in the car
http://www.youtube.com/watch?v=x9AUzaz_MyI
not an acura, a mustang, but its basically SAME EXACT thing
put it ignition
turn up
press button
turn down
press button
turn up
press button
take the key out
put it ignition
turn up
press button
turn down
press button
turn up
press button
take the key out
put it ignition
turn up
press button
turn down
press button
turn up
press button
take the key out
joflewbyu2
Oct 8, 2015 11:16 AM
SinCityTLX
Oct 7, 2015 01:24 PM
