Problems
Old Mar 6, 2009 | 05:00 PM
cvzillest's Avatar
Problems
My car has both the ABS & TCS light on, what would cause this to happen? and it wont shut off either. occasionally itll shut off then when the tires slip itll stay on 4 weeks again. Also, is it recommended to change the brakes after 60k miles? when im on the highway going about 65-75 when i brake the wheel shakes violently and so does the car. could this be part of the ABS & TCS light?
And Ive been hearing talk about the transm. problems the acura 2nd gen. has. how do u kno if ur affected?
Old Mar 6, 2009 | 06:15 PM
juanclopez2786's Avatar
you'll have to have some1 scan the car and see why the abs light is on. could just be a wheel speed sensor but you have to get some1 to scan it and see. as for ur braking at 65-75 and the wheel shaking your front rotors are warped so you should look into gettin them machined within spec or just replaced. my car is doing the same thing right now im just savin up for some drilled slotted rotors for front and back. and you trans question can be answered by clicking here
Old Mar 7, 2009 | 08:39 PM
jokerjuice's Avatar
hey i have a 1999 3.2 tl and i have 2 questions...I just put tein ss with dampering on my car right is it okay if its on stiff the whole time. and now recently i start hearing like this squeeking noice when you squeeze a rubber ducky i only hear it when i go over bumps and little pot holes its driving me crazy i cant really tell where its comin from can someone please help me out i will really appreciate it soo much thank you.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
