problem with fuel guage reading?
Old Nov 25, 2008 | 10:25 PM
eleventure's Avatar
I've just noticed this after my last visit to the gas station.
After I filled up I noticed that my fuel gauge isnt reading correctly. The needle stopped 2 1/2 notches below full. I was thinking that I just needed time to get up to full cause sometimes it moves up to that mark slowly but the next day it was still at that point. So I went back to the gas station the next day to top off thinking that the pump clicked off too early the previous time but same thing happened.
Does anyone else have the same problem?
Im not sure if it is the fuel sensor, the gauge itself or something entirely different that's causing me to get an inaccurate reading.
any insight would help. Thanks.
Old Nov 26, 2008 | 07:08 AM
fsttyms1's Avatar
Just like you assumed, It would either be the gauge or the sending unit. How to test with something that minimally off?? Does it read accurately the rest of the way to empty as driving it (like when the low fuel light comes on is there roughly 3 gallons left?
Old Nov 26, 2008 | 10:29 AM
NSXNEXT's Avatar
The symptoms you describe sound just like a bad sending unit.
Old Nov 26, 2008 | 12:10 PM
totaledTL's Avatar
On a related note, around here a few yrs. ago some fuel w/ excess sulfur (I believe that was the problem) got distributed to some stations. It screwed up the sending units in the cars that used it & the fuel dist. had to pay for repairs of the affected cars.
Old Nov 27, 2008 | 02:05 PM
MickeyTL's Avatar
This had happened to my acura legend and I had to replace the fuel sending unit. It did fix the problem. Bought used fuel sending unit for $50 and installed myself. Took 1 hr. to complete.
Old Nov 28, 2008 | 02:11 AM
eleventure's Avatar
Yeah i might take a look into that. Are the fuel sending units connected to the fuel pump or does the tank have to be dropped?
Old Nov 28, 2008 | 02:15 AM
eleventure's Avatar
I did fill up on base previously to this happening.
Old Nov 28, 2008 | 09:02 AM
rob-2's Avatar
Not likely an issue. I've been running regular for a while now. Sometimes the units just fail.
Old Nov 28, 2008 | 09:11 AM
01tl4tl's Avatar
try some fuel cleaner in the tank to see if glaze is making the sendor stick
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
NBP_BALLER
Sep 23, 2015 08:18 PM
brandnewcolony
Sep 12, 2015 10:39 AM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
NSolace
Sep 3, 2015 08:14 PM
