problem with 99tl
problem with 99tl
i'm having problems with my tl. sometimes when i start the car, the idle drops and then the car dies out. i mean its only happend to me once, but sometime i let my brother n them drive it and they tell me that it happes to them couple of times now. also happens to a friend of mines which owns a 00 tl. can someone tell me whats going on or has anyone experence this?
I would suspect the EGR passageways inside the intake manifold are severly plugged
See DIY on thermoblock install/EGR cleaning
Call acura and ask if you are covered on the EGR warranty 1-800-382-2238x5 Have your VIN number ready
on the 99s they were having the dealer clean them and install a sleeve in the port- the sleeve doesnt really help but they tried!
Hows the spark plugs and tune up parts looking?
i have the same problem i have had my 99tl for bout 2 yrs and it only happened like 3 times. i jus give it a lot of gas and it throws it right out....then its fine. It usually happens when its a bit warmer outside. Who knows???? mayb we need a tune-up!?
well for some of us it can be a tune up but i gave my car a tune up already, so its defenetly not that for me, but it can be that some of us need to clean the egr ports.. i have to clean mine so im sure once i do that my car will be at its 100%
how many miles on your car. sounds like a problem I had for a while. I changed my spark plugs and replace some of my distributors and it fixed it right up. it's probably a sign telling you one of the distributor is going out. I chose to ignore it and it took out three of them... which is very uncommon for an Acura.
03 ABP tls
what and where is a distributor?
coil pack
Distributorless technology, utilizing independent coils for each cylinder.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
