Preventative Maintenance
Old Jul 24, 2006 | 08:18 AM
johnb102's Avatar
5th Gear
I just purchased a 2002 TL Type S with 76,000 miles. I was only able to get a partial history of the service that has been done (including the new transmission). It was dealer serviced, but mostly just oil changes and fixing minor problems. I would like to start doing maintenance with the plan being to keep the car for 10 years.
The list I could think of included:
* Fuel Filter
* Air Filter
* Spark Plugs
* brake fluid flush
* Coolant flush
* Transmission flush
* timing belt/water pump
I have an independent mechanic who lets me buy the parts and he installs them, so I am putting together a shopping list.
Some of this, like the timing belt/water pump can probably safely wait a couple of years. Is there anything else that should be added to the list?
Old Jul 24, 2006 | 09:04 AM
fsttyms1's Avatar
Fuel filter is just a filter in the tank. Its a sock. No need changing it. Spark plugs should be good to 100k. brake and coolant flush, wouldnt hurt but probably not necessary. tranny is just a 3 quart drain and fill. there is no servicable filter on it to replace. timing bet/h2o pump should be good till 100k
Old Jul 24, 2006 | 09:55 AM
optomos's Avatar
I=X - optomos
Cabin filter, engine mounts, and EGR cleaning. Spark plugs can wait till 100k.
Old Jul 24, 2006 | 10:23 PM
sbuswell's Avatar
I need 2 more gears
clean your fuel system, do a coolant exchange every year, tranny drain/fill(only, do not do a flush) once a year, changing plugs at 76k is not a bad idea, but not necessary. also changing cabin filter every 25k is recommended. cleaning egr valve cannot hurt especially if you spend 110.00 and put the thermoblok spacer kit in while you're at it. chaning power steering fluid is never a bad thing. changing brake fluid is not necessary unless you are changing your brakes. these cars need minimal maintenance, just change your fluid at or before the recommended intervals and your car will run great.
Old Jul 25, 2006 | 02:17 AM
PenancE's Avatar
personally if u know how to change plugs and if its easy for u, do it, cause those lead to coil pack issues, and it becomes a bitch when it happens......
Old Jul 25, 2006 | 05:38 PM
Scj's Avatar
Scj
What and where is the Cabin filter?
Old Jul 25, 2006 | 05:46 PM
fsttyms1's Avatar
https://acurazine.com/forums/showthr...t=cabin+filter
Old Jul 27, 2006 | 01:30 AM
adamlee05's Avatar
Thread Police Chief
Kinda Hijacking the thread a little bit, but anyone know where to get new coil packs for cheap? I JUST missed out on this last night
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
