Power Mirrors not working
Old Aug 11, 2009 | 12:51 AM
dmjh216's Avatar
6th Gear
Hey guys, I just picked up an 03 tl. Everything is fine but I noticed the power mirrors are not functioning when I put the car in reverse. It was working when I was test driving it. Any ideas on what may be the problem? Thanks
Old Aug 11, 2009 | 07:20 AM
fsttyms1's Avatar
make sure the mirror switch is in the middle position. If its not the reverse tilt down function doesnt work.
Old Aug 11, 2009 | 01:32 PM
spoka's Avatar
^ x2
Old Aug 16, 2009 | 09:47 PM
dmjh216's Avatar
6th Gear
all fixed. thanks!
Old Nov 1, 2018 | 01:53 AM
Win's Avatar
Win
Power mirror switch question
Hello would anyone know if the mirror switch has a bulb that illuminates when the headlights are turned on and what type of bulb if any? Thanks!
Old Nov 3, 2018 | 02:27 AM
Win's Avatar
Win
Power mirror switch light
So apparently there is a bulb inside the switch but it is soldered on a circuit board and will need a 12 volt replacement from an electronic parts store. The cap for the heated mirror button can be gently pried off with a small flat screwdriver then the 2 halves of the switch can be separated with a small sized pry bar. That will access the circuit board and a new bulb soldered onto it. The little green condom can be removed for more light.
rockyboy
Aug 4, 2024 10:35 AM
chrisr
Dec 4, 2015 02:17 AM
sockr1
Oct 1, 2015 01:31 AM
acurajj
Sep 19, 2015 03:47 PM
PortlandRL
Sep 14, 2015 12:01 PM
