Please Help...hid problem
Old Aug 15, 2010 | 01:56 PM
acu23's Avatar
Ok guys so here is whats going on, i have a 2003 tl and the driver side low beam headlight has gone there is moisture in the housing so i took the bulb out and put it on the pass side and it works fine what else could it be...
Old Aug 15, 2010 | 03:49 PM
gold2003tl (90)'s Avatar
2003 TL-p
ballast/igniter got toasted from the water that got inside. you can replace it with an oem ballast which will run you a pretty penny. or you can custom fit in an aftermarket hid system. first find out how water got inside and fix the leaks. also check the black market and see if anyone is selling used ballasts and ebay.
Old Aug 15, 2010 | 06:19 PM
01tl4tl's Avatar
yeah the water gets in thru a bad seal most often
see the diy threads on resealing or look for aftermarket housings online
there is a vent/drain hole on the bopttem of the housing which drips directly onto the ballast shorting it out
score one from the local auto recycler yard or get an aftermarket unit/kit
If getting new bulbs stay with 4300k stock color, or 5000k more blue
Old Aug 15, 2010 | 08:38 PM
acu23's Avatar
damn guys really appreciate your help, i guess the next question is how do i get to the ballast?
Old Aug 15, 2010 | 08:54 PM
2003 TL-p
you will have to remove the headlights, which is easy.
take the front bumper off which is very easy, https://acurazine.com/forums/showpos...58#post1870075
and then unscrew the headlights, which is pretty straight forward.
with the unit out, the ballast can be taken off. its on the bottom and is a small gray aluminum box which is held in by a few screws.
Old Aug 15, 2010 | 08:57 PM
2003 TL-p
check out the DIY sticky thread on the main section, it has other DIY and things that might help with this.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
