Placement of hid bulbs
Old Oct 30, 2010 | 09:45 AM
sunland man's Avatar
When replacing hid bulb in a 2002 tl does it matter which way you place them? Looks like its possible to reinstall them in two differrent positions a 180 degrees apart. Is there a up or down on theses bulbs?...thank you in advanced!!!
Old Oct 30, 2010 | 10:58 AM
01tl4tl's Avatar
yes -install the external thing up or down same as the bulb you pull straight out
watch the retainer clip is on secure-bulbs in tight etc
see diy section for help- need torx #20 security bit to remove plastic covers on rear of light housings
Old Oct 30, 2010 | 11:00 AM
01tl4tl's Avatar
of course rubber or latex gloves when handeling bulbs- finger oils cause hot spots and early bulb death
Old Oct 30, 2010 | 01:20 PM
soria's Avatar
+1 on the gloves^^^
Form what I remember the bulbs only seat in correctly one way? Just make sure the retaining clip snaps on and the bulb isn't moving. Study how the current ones are positioned before you take them out and copy for the new ones.
Old Oct 30, 2010 | 07:41 PM
01tl4tl's Avatar
with the abilty to use 3 different bulbs in our setup- one can install the bulb wrong way up!
always look at what you are doing on removal
that clip is the pita~,,study it with small mirror or remove entire light housing to work on
Old Oct 30, 2010 | 10:26 PM
soria's Avatar
...and disconnect the battery for at least 5 minutes before you do it. Just to be safe
Old Oct 31, 2010 | 06:06 AM
01tl4tl's Avatar
its use of the headlight itself is what causes residual power to be in the HID parts
after shutdown
let the car sit at least an hour after lights use, or preferred overnight so everything is dead cold,,rather than you being cold dead~
01tl4tl's Avatar
know the radio and nav codes!! you will need them if battery disconnected
hashbrown
Feb 18, 2022 11:20 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
AmplifiedDetails
Sep 24, 2015 02:55 PM
