Pass side vibration
Old Aug 19, 2011 | 09:12 PM
Diva 4 Life's Avatar
99Ackrite
Pass side vibration
Hey all, when I'm under acceleration HW speeds I have a vibration I assume its axle related correct? I know the thing needs replacement anyway boot is busted. The previous owner just drove the ish out of it. Do these cars have a countershaft on them where the right axle is a half shaft basically?
Old Aug 20, 2011 | 06:36 AM
fsttyms1's Avatar
Odds are you have a axle issue. 2 other things to check is your tierod and the carrier bearing for the intermediate axle that the p-side axle slides into for axle play.
Yes, there is a intermediate shaft with a carrier bearing in it that the axle slides into making it a equal length axle setup.
Part 17 is the intermediate shaft. I have a bearing going in that that is currently causing my acceleration vibration (hwy speeds) but i have 450k miles on it.
Old Aug 20, 2011 | 10:32 AM
99Ackrite
I kinda figured it had this setup, let me know how expensive this is too replace when you get yours done.
Old Aug 20, 2011 | 12:10 PM
01tl4tl's Avatar
a new axle with cv bearings and new boots are ~$100 at NAPA auto parts
NEW is better option than rebuilt when you have a choice- for this part
torn boot means grease gone and grit in = total failure of part at very bad time
Old Aug 21, 2011 | 10:03 AM
99Ackrite
I know exactly what you mean 01tl4tl. I was referring to the carrier bearing setup that fsttyms1 has to have replaced on his. I have a local shop that is going to replace my axle with a NEW one for 175. Parts and labor, I don't think thats too bad.
Old Aug 21, 2011 | 10:06 AM
fsttyms1's Avatar
You can get the bearing and seals thru the dealer (or the link below) for about 45 bucks, then you just have to have a shop press it in.
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Aug 21, 2011 | 03:56 PM
99Ackrite
update
Hey all, I checked the axle and carrier bearing today and the carrier bearing is fine but the inner boot is busted also, didn't know that. It has play in it pretty bad so I can see why it has a vibration. I will update again tomorrow after I get the axle replaced.
Old Aug 21, 2011 | 05:51 PM
01tl4tl's Avatar
better that than the more expensive option!
Old Aug 21, 2011 | 09:54 PM
99Ackrite
I know right thanks for the info 01tl4tl
marcelft
Jul 10, 2018 06:17 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 09:01 PM
Sep 17, 2015 10:09 AM
tmux
Aug 31, 2015 10:27 PM
