Parking Brake light
Old Oct 11, 2008 | 05:25 PM
soria's Avatar
Parking Brake light
Sometime after I remove the parking brake, the light still remains lit in the dash. Has anyone experienced this?
-Daniel
Old Oct 11, 2008 | 08:56 PM
fsttyms1's Avatar
is the pedal retracting all the way?
Old Oct 12, 2008 | 01:43 AM
Stimpy's Avatar
it happens to me, but only in the mornings when its cold out. i need to look into whats causing it. it wears off in a few mins tho. faulty switch?
Old Oct 12, 2008 | 01:47 AM
97rlegend's Avatar
if your brake fluid is low the light will come on to warn you.
Old Oct 12, 2008 | 12:09 PM
Stimpy's Avatar
yeah i've read that several times in other related threads...my fluid levels check out. i know i also read that a faulty reservoir cap can also be related.
Old Oct 12, 2008 | 06:40 PM
soria's Avatar
Yes, the brake is all the way off. I'm not sure what the problem is.
I'll check the brake fluid.
Old Oct 13, 2008 | 02:01 AM
ftLauTL's Avatar
Ya....It's an Acura
ya either the fluid or cap to the resevoir would be your best bet, also the light can come on I think to warn of other brake-related issues
Old Oct 26, 2008 | 05:05 PM
soria's Avatar
I forgot to check back with this thread until now. My fluid levels check out. How would I fix the faulty cap, is that just replaced with a new one?
Old Oct 27, 2008 | 01:46 AM
01tl4tl's Avatar
its about 35$ for a new cap by itself
Check the electrical connections on it first
That should not make a PARK BRAKE lamp come on though- a master warning yes
if its park brake lamp- check the switch- should be one behind the park brake pedal
Is it every time you use park brake, or stays on all the time now or whats happening?
Old Oct 27, 2008 | 07:12 AM
fsttyms1's Avatar
Make sure the float moves freely. Look for any gunk on it and clean it up a little.
Old Oct 27, 2008 | 01:03 PM
soria's Avatar
It just turns on whenever it wants. Even if I haven't used the parking brake, when I turn on the car sometimes the light turns on and then it'll turn off later or sometimes it remains lit.
Old Oct 27, 2008 | 02:13 PM
01tl4tl's Avatar
as long as its the park brake lamp- thats more likely a switch issue- behind the `parking brake pedal`, to tell the light to be on or off
It could be worn out or loose
Same thing happens to the actual brake pedal switch that operates the brake lights- it gets worn or grungy and gives up
easy DIY job for either
If its a master brake warning then suspect cap
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
jliu6789
Sep 8, 2015 08:02 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
