P0420 and new Cat
P0420 and new Cat
After trying my luck with EGR cleaning and changing the O2 sensor, my CEL is still on so looking to change the cat at 160k miles
Any feedback on the Magnaflow 27402 direct fit. I could not see a YouTube video of this. Do you recommend any DIY thread, I could not find it
Thanks for your response
Was an "OEM" Denso brand O2 sensor used to replace the old one with ?
If the cat is bad, the car's motor usually bogs down and the exhaust will smell bad.
Check with the site's vendors for replacement free-flowing cats.
ask your local muffler shop what to use, a generic obdi2 cat for 100-150 bucks or high flow cat (most require a $10 mod to correct flow rate to O2 sensor)
DIY is spray wd or similar on bolts the night before
remove nuts/bolts and remove cat
install new cat- use new hardware (bolts/washers) if available
what codes are you getting now?
you did the full remove intake manifold to clean egr and poked it correctly?
upper gasket was installed correct side up?
Thanks all. Quick follow up.
Any recommendations on the 2 variations of Magnaflow.
Magnaflow New York/Catalytic Converter 49258 at AutoZone.com
300 bucks - is classified as OEM grade
or the
Magnaflow New York/Catalytic Converter 27402 at AutoZone.com
It sells for 199 $...
or the
I just ordered a new magna flow cat. Though I have done things under the hood (TB cleaning, EGR cleaning, etc), I have not done cat replacement. Any suggestions for this one, do I need to jack up the car to replace cat (the tip to spray WD40 overnight was helpful). I searched but did not find a DIY post that covers start to end (with photos or youtube). Any links appreciated.
Just keep in mind what you're dealing with. The old exhaust parts are going to be contrary to remove & replace.
You will require room to work on the stuff, so safely find a way to support the car.
Rust and heat kills the old mounting hardware, so be prepared to improvise along the way.
if you get in there with the penetrating lube and it looks like nothing but rust
Put the car down!
drive to the local small muffler shop where a few dollars will get the job done
having room to pull a breaker bar is crucial on rust seized nuts
(sounds like a personal problem old guys get)
NOTE: try tightening stuck bolt/nut slightly- to break that bond, then remove
These jobs are either cake, or they eat your lunch
Put the car down!
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
DerrickW
Nov 15, 2015 05:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
