P.Steering pump noise
Old Aug 10, 2010 | 01:58 AM
winhansse's Avatar
My P.S pump making noise really bad when engine cold start. I've order the used one for $45 and plan to change it myself. How do you remove the top hose( metal one) and release P.S pulley belt?
Yes, I did reserch the prob and some people sovle poblem by fixed leak, not over tighting the belt or some end up to change P.S pump.Thanks.
Old Aug 10, 2010 | 03:55 AM
01tl4tl's Avatar
fries should be here with the answer soon!
Old Aug 10, 2010 | 12:56 PM
TLer trash's Avatar
Have you so much as checked your fluid level and condition?
Old Aug 10, 2010 | 03:39 PM
my.daily'tl''s Avatar
Always Working In
What year are you? There was a recall about power steering noise on some models fixed by a redesigned o-ring.
Old Aug 10, 2010 | 07:08 PM
winhansse's Avatar
Thanks Tom & everyone. fluid level is good now. My problem started back to 2 years ago, I didn't know the fluid leaked out from top of reservoir's lid until a few month ago. Well, I fixed the lid by wrap w/ PVC tape inside the screw look part and it no more leaking from the lid.
I knew it was always on minimum line so I thought it was OK to drive. I think the damage was done inside during the time.
Ok I figuare out about remove top metal hose which 2 nuts loosen and reuse the top part back.
I saw long thread screw one between and under P.S pump, engine. Is that purpose for adjust the P.S belt or what? Can I uncrew it to release the P.S belt?
Thanks again. Oh yes, 99 Tl I think we don't have o ring or I could be wrong.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
