P 401 2001 Acura TL
P 401 2001 Acura TL
I have changed the EGR valve with an original Honda part, reset the OBDII code, however after 10 miles the code has reappeared. Any suggestions?
^ yea i agree. its most likely a clogged port. there should be a kit you get from acura that has the new egr valve, new gasket and a metal sleeve. to fix it you gotta remove the intake manifold and drill out the carbon build up. once you do that you just hammer the sleeve in and put everything back together.
sockr1
10-01-2015 01:31 AM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
asahrts
09-04-2015 05:55 PM
