overheating again
UB6IB9
overheating again
i just changed the thermostat 2 weeks ago because my car was overheating and this morning it started overheating again. While in park the temp gauge was up and as soon as gave it some gas the temp dropped. What could it this time?
did you bleed the system when you added the coolant after replacing the thermostat? if not try that first, just take the radiator cap off and run the car till all the air comes out of the system. they have coolant funnels that fit right on the radiator that make it easier. when i bleed the system i let the car run til the fans kick on twice and then thats when i put the radiator cap back on.
so when u revved it up it cooled down? the only thing i can think of is that the fan turned on when u revved up....revving will only increase the temp like acutee stated. try what juan said. mainly because it happened to me be4, i didnt have enuff fluid inside, air got in, and kept overheating after 10 min of driving, let it bled and was fine again. if it still does it i would check ur water pump and the tstat again. if anything to test the tstat, put it in boiling water, drop it in the cold pot, then crank the heat, and look for it opening...u would need specs, and a heat gun, but if it opens up u can rule that out.
UB6IB9
I'm changing my timing belt and water pump soon along with the tensioner,what else should i change since i'm doing all this?.How can i check if the switch is in working order?
Is this the same process I'm supposed to follow if I have added some coolant and/or want to bleed air (not after a drain and fill).
In my case my reservoir is already at max and my radiator full. I want to bleed the system but running my engine with the cap on doesn't drop the level.
If I remove the cap and run the car the level in the radiator rises and then overflows.
UB6IB9
This is getting annoying.Today as i'm driving the temp was normal after a while as i came to a full stop the temp dropped all the way down and as i accelerated it went up till half way maybe a bit more and when i stopped again it went all the way down...WTF!!!
Seems like a malfunctioning temp gauge!!
sounds to me like you might need to have the cooling system pressure tested making sure theres no air getting into the system. bring it somewhere so they can vacuum the cooling system till all the hoses are flat and then fill it knowing theres no air in the system. if that fails you should look at having a cylinder leakdown test to make sure your head gasket isnt blown.
UB6IB9
Could it be a malfunctioning temp sensor?
UB6IB9
Turn the ignition switch on (II). Set the displayed temperature on the climate control system to 90°F (32°C) , then turn off the ignition switch. Make sure the engine and radiator are cool to the touch.
Remove the radiator cap.
Install the radiator cap loosely.
Start the engine and let it run until it warms up (the radiator fan comes on at least twice).
Turn off the engine. Check the level in the radiator, and add Honda All Season Antifreeze/Coolant Type 2 if needed.
Put the radiator cap on tightly, then run the engine again and check for leaks.
UB6IB9
UB6IB9
Once again i loosened the cap and let the car run for a good 10 mins,temp gauge was reading normal temp but the fan did go on.Went for spiritted ride and the temp remained at normal.
UB6IB9
I was driving the car today and the temp was fine and then all of a sudden,the temp gauge dropped all the way down and got a code 006. After about 5 mins,the temp went back up to normal.What could this be?
UB6IB9
After my drive back from work i checked to see if the fan was working. With the a/c on,they both work but when i turn off the a/c,the driver side fan does not go on.I drove with my car for 15 mins and when i came home i waited for another 5 mins but the fan never came on.I guess the fan switch needs to be replaced. Is it under the rad on the 00 TL?
Good catch
Hey way to go,
It seems that 2nd Generation TL's have that problem. I recently had to replace and now everything is all good.
Have you replaced that blower motor and sub-harness yet?
