OEM rotor and pads part numbers
Old Oct 28, 2009 | 11:26 PM
TL45's Avatar
Hi,
I am getting my front rotors and pads replaced again! This will be 3 times in 5 months! It has been a nightmare in my wallet. Anyway, this time around I am getting OEM parts. I have a friend at Toyota that will have the work done for me at a great rate so I just need the parts.
How can I find OEM rotor and pads part numbers for my car so I can order them from Honda? It's a 2002 TL-P.
Any help is appreciated.
TIA
Old Oct 29, 2009 | 06:55 AM
fsttyms1's Avatar
Why order OEM parts, they arent any good. contact our vendors and get teh rotors and pads from them, OR order the brembo blanks from tirerack.
If your set on oem
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Oct 30, 2009 | 03:08 AM
Edward'TLS's Avatar
6G TLX-S
Originally Posted by TL45
Hi,
TIA
If you get the brake job done in Honda/Acura dealerships, there will be warranty on the brakes.
Old Oct 31, 2009 | 08:24 PM
totaledTL's Avatar
Which brand have you been using 3 sets of in 5 months-!?
Old Nov 3, 2009 | 08:07 AM
TL45's Avatar
It is actually 2 sets. My next set would make the third. But they were some cheap aftermarkets. The last set was from China.
Old Nov 6, 2009 | 11:26 AM
TL45's Avatar
If your set on oem
How do I get in touch with the vendors(pls excuse my ignorance)? I am interested in getting brembo blanks. Thx again fsttyms1 for the suggestion.
Old Nov 6, 2009 | 03:27 PM
fsttyms1's Avatar
https://acurazine.com/forums/sponsored-sales-group-buys-10/
Excelerate and Heeltoe for starters
Old Nov 13, 2009 | 08:42 PM
TL45's Avatar
So I had someone install Brembo rotors a couple days ago... Now I have come to find out they are actually Roto-Tech rotors (3175 R/L and 3186 R/L). I'm pretty cheesed about it. Does anyone know anything about this brand/model?
thx
Old Nov 15, 2009 | 12:31 PM
TL45's Avatar
Ok this is almost painful to write... This has been my THIRD set of rotors and pads installed within 5 MONTHS now. The most recent was less than 1 week ago. I am now getting the exact same sound of a warped rotor again. I am begining to think something else is causing this. Any ideas?
TIA
Old Nov 15, 2009 | 02:58 PM
TL45's Avatar
so basically I'm thinking something else is causing my brakes to not function properly thus warping the rotors all over again. But these rotors have all been cheap quality so it can possibly be the fact that they are cheap. I'm just worried about getting a set of Brembos now and then watching them warp along with all the other sets rotors.
Old Nov 15, 2009 | 08:18 PM
totaledTL's Avatar
What about the calipers? How fresh is the brake fluid- is it nearly clear or brownish? Maybe you have a sticking caliper causing excessive heat buildup.
Old Nov 15, 2009 | 08:59 PM
hANDYcaptd's Avatar
It's the Halladay season!
Are you bedding them in correctly? My first guess would be that they're getting too hot, too soon. And causing the early warping.
Old Nov 15, 2009 | 09:28 PM
fsttyms1's Avatar
I wouldnt bed pads in until i had at least 500 miles on them.
If you are warping them that easy i would say that you probably have a caliper issue. You may also have a rear rotor that is causing the pulsation. And what to you mean by
Warped rotors shouldnt make a sound, they cause vibration.
Old Nov 15, 2009 | 10:19 PM
hANDYcaptd's Avatar
I always thought it was right away...
I re-read the Heeltoe bed in process. He does mention that about the Racingbrake rotors. I guess it can apply for all performance rotors?
So is it... no hard braking for 500 miles, then do the bed in?
Old Nov 15, 2009 | 11:39 PM
TL45's Avatar
Interesting, because I do not really feel a vibration. I can feel something slightly in the brake pedal when braking but hardly noticeable. The sound is like loud grinding or squeaking only when I brake. The sound is not continuous while braking... it seems while braking, as it spins over a certain part it grinds/sqeals.
Thanks 2 every1 who added their input!
Old Nov 16, 2009 | 08:35 AM
fsttyms1's Avatar
I follow that procedure with all my rotors. I always like to cycle the rotors and give the pads time to break in and wear to the rotor. I have never warped a set of rotors (well at least not before at least 60-70k miles)
Old Nov 16, 2009 | 01:32 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
Worn out pads- metal on metal, or wear warning indicator now touching the rotor??
Old Nov 16, 2009 | 06:01 PM
TL45's Avatar
No they are brand new pads and rotors all around. It did not make the noise today. But I feel it will come back. I think something else mechanically is causing the the brakes to make the noise. Probably the calipers as fsttyms1 said.
Old Nov 20, 2009 | 08:09 AM
TL45's Avatar
ok if it's not the rotors since there is no vibration just a loud sound and the pads are all new. what other possibilities could cause such a loud squeaking sound? I have been fixing the wrong thing for 3 times now. I just know that the sound happens only when I brake. It sounds like it is coming from the front. Could it be the brake fluid as totaledTL said? I haven't had time to investigate the calipers yet.
One thing I have noticed is when I changed the rotors, the sound went away for about a week. Then came back.
Thanks for your input guys.
Old Nov 20, 2009 | 09:58 AM
totaledTL's Avatar
Could it be the anti-rattle spring clips rubbing making that sound? That wouldn't cause warping though.
Old Nov 20, 2009 | 03:09 PM
TL45's Avatar
Hi totaledTL, thanks for the further suggestions. What could the anti-rattle spring clip be rubbing against? I will try and look into this later.
Thx
Old Nov 24, 2009 | 11:44 PM
TL45's Avatar
I just wanted to let you guys know that I think I have fixed the problem. I had just replaced the drivers side front caliper. It only cost me $60. My friend, two different mechanic shops, and an Acura dealership told me the problem was my rotors.
On the downside, now my brakes squeal.
Old Nov 25, 2009 | 08:30 AM
fsttyms1's Avatar
the rotor probably wasnt releasing properly or applying even pressure. Place some anti squeal on the back of the pads and some caliper/pad grease where the pad touches the bracket.
Shaqs2002TLS
1/2G MDX (2001-2013)
Sep 20, 2015 05:23 PM
jfman55
Sep 5, 2015 02:55 PM
darksky
Sep 5, 2015 03:11 AM
