Odd Sound - Startup - Transmission?
Hello All,
I am new to the forums and there seems to be tons of knowledge here! I did some searching before I decided to make a post but didn't find anything.
BTW: I just purchased a 2003 Acura TL Type-S and I love it.
So here is my issue:
After I start the car and put into reverse to back down my drive way, after I get moving a bit I here a buzzing sound that vibrates the floor a little and lasts about 2 seconds. Then I put the car into drive to go down my street and after about 20 feet or so, it will repeat the same sound, but only for 1 second. It doesn't repeat until I shut the car off and let it sit. It sounds to me like a pump is pressurizing something, and since this only happens when putting into gear, I am connecting it with the transmission. Anyone have any ideas, but its driving me nuts!?!?!
im glad somebody mentioned this. i have the exact same issue except mine buzzes 5 seconds after i put the car in drive and again at 10 seconds. i thought my tranny was going berzerk after i first heard it but it shifts smooth and i got no codes. i wonder what it is?....
Yep, ABS. My old Accord used to do this, but the ABS was damaged and it would make that buzzing sound for about 5 minutes, so I just unplugged the terminal to the ABS pump.
DO NOT UNPLUG THE CABLE just because of the noise in your TL. You most likely will not have ABS anymore. enjoy braking.
Thank you for the info. I won't be disconnecting it unless it is going haywire.
I really dont know on the TL, but on my Accord it was located near the brake fluid container on the right side of the engine. It was a little black box with a orange cable on it.
