O2 problem
Old Jan 23, 2012 | 04:26 PM
MAKE.IT.LEGAL's Avatar
7th Gear
O2 problem
I have an 01 acura tl and I replace my sensor2 with an aftermarket and a hollow cat. It worked fine for about 6 months then the sensor went out. Well I went ahead and bought an oem sensor. I had to soder the female connection back to the wiring harness so I could connect the new oem sensor. I reset my check engine light. I turned the car on and drove for about 10 miles turned the car off and then back on and drove the car again but the check engine like came back on with in a mile or two. The code that I keep getting is p0137. I am just wondering if its the hollow cat that is causing this or maybe i have the wiring incorrect. If someone can help me with this I would really appreciate it.
Old Jan 23, 2012 | 04:40 PM
TLer trash's Avatar
I'd take a close look at your wiring. The p0137 code is for low voltage on the rear o2 sensor. A gutted cat will typically throw a p0420 code.
Old Jan 23, 2012 | 05:02 PM
7th Gear
Ok thanks......i just need to see if anyone has the wiring diagram to that o2.
Old Jan 24, 2012 | 11:00 PM
7th Gear
I am stuck on 2 wires. Dont know which go together. Here is what I have.
Harness Sensor
Green Gray
Green and yellow Black
Black and white White
Black and yellow White
I know that the black wires go with the white wires obviously. I know that the Gray wire on the sensor is ground and the black wire is signal. I just dont know which green wire is which on the harness. If someone knows, I need your help bad. It sucks driving looking at the check engine light and gas gauge just moving quicker than normal.
Old Jan 24, 2012 | 11:04 PM
7th Gear
Im sorry on the colors
Harness has: green, green&yellow, blackwhite, blackyellow
Sensor has: white, white, black, gray
Old Jan 24, 2012 | 11:51 PM
01tl4tl's Avatar
its the soldering that screws up the wire resistance(?) and changes operation of o2 sensor
they are pretty thin wires as I recall, others have had prob when not using the Denso brand, which is a `plug and play` sensor --no cutting wires
with your cat gutting- you need to run a shroud around the sensor to slow the flow rate closer to normal
buy a 14mm `spark plug anti fouler device`- 5-10$ parts store item
have to cut much of its end out, see many pics on azine for help,,probably in the diy too
all hi flow cats need it, so yours would qualify~
Old Jan 25, 2012 | 12:03 AM
7th Gear
I am going to do that. But I still have to figure out the color coding on the wires and then I still have no choice but to solder the female end so I can plug the sensor in. I hope this works. Still appreciate the input
Old Jan 25, 2012 | 10:11 AM
01tl4tl's Avatar
get some electrical solder- very fine stuff,,try radio shack
anyone else with an 01,, and good enough weather to crawl under and look at the wire connector? thanks
Old Jan 25, 2012 | 11:55 AM
7th Gear
lol it seems like that is the only way I am going to find out the correct wiring. Thanks for your help again.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
