Noob Needs help with rear rotor replacement Caliper bracket rubbing
Old Jun 3, 2010 | 11:22 PM
colinzarbough's Avatar
Hello all. I am currently in the middle of replacing rear rotors on a 2003 tl type-s and having an issue with the caliper bracket. I bought new rotors from Brakemotive and replaced the front ones easily, but the rear are a pain in my butt. The new rotors don't sit as deep on the studs as the old rotors. It is causing some rubbing on the dust shield behind it, but I still don't think that's the issue. There just isn't any clearance. There is some serious rubbing going on, and I have no idea what to do. I have attached a link to some pictures to show there is no clearance, and please let me know if there is anything I need to do further that I probably have forgotten. Thanks for all your help.
http://home.ubalt.edu/colin.zarbough/acura.html
Old Jun 4, 2010 | 07:03 AM
totaledTL's Avatar
Are you certain they sent you the correct rotors? Call them w/ the #'s to verify.
Old Jun 4, 2010 | 07:26 AM
01tl4tl's Avatar
the rear rotors contain the Park Brake Shoes- a mini set of drum brakes are inside the wide part of the center hub- rear rotor
If the park brake is ON- you wont get the new rotors all the way on
Compare the new and old parts on that center section
and you will need to readjust park brakes after new rotor install
There is a star wheel on bottem section- use that opening in rotor to stick a screwdriver inside
tighten till wheel wont easily move by hand- then back off 6 clicks
Old Jun 4, 2010 | 02:53 PM
hey guys. working with brakemotive now. they are checking the specs to see if they were made correctly. Old rotors fit back on fine with my hubs, new rotors just don't have enough clearance. They are not sitting deep enough on the lugs. Let you know what I find out. Gracias.
Old Jun 6, 2010 | 12:49 PM
myisanog's Avatar
yeah . make sure park brakes are off
Old Jun 6, 2010 | 01:07 PM
smartypants's Avatar
Hi Colin :
I can't see how they were manufactured not to fit. If the casting is just plain wrong, you're going to have to return them and I suspect that's were you're going. It's good to see the supplier is working with you, but they should be compensating you for all the "quality assurance" you're doing on their behalf.
It's kind of a testament to sticking with OEM parts.
Good luck with your project !
smartypants.
Old Jun 6, 2010 | 07:22 PM
01tl4tl's Avatar
maybe the inner hub lip is in too far- iirc thats what another maker encountered when they started making gen3 rear rotors and they wouldnt go on
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
