New Gauge Cluster
Old Jul 13, 2008 | 09:56 AM
Forevafire's Avatar
New Gauge Cluster
So my stock gauge cluster was starting to go. When I would shut the car off the needles would not go down all the way. I looked on ebay and found a used gauge cluster from a TL-S (mine is a TL-P). I prefer the white gauges over the black so I went with this one.
I installed the new gauge cluster, all the harness lined up correctly. When I turned on the car the Check Engine light was on and the VSA. I know the TL-P does not have VSA so I am not worried about that. I just wanted to see if you guys knew why the Check Engine light was on. I still haven't taken it to Autozone because I didnt think it was a big deal since the Check engine light was not on when I still had the stock gauge cluster in.
Any ideas why these lights came on?
Old Jul 13, 2008 | 01:31 PM
Forevafire's Avatar
Ok so I just went to Autozone and no code came up.
Edit: It is not the Check Engine light it is the Mant. Req. light.
Old Jul 13, 2008 | 04:37 PM
FuriousSam's Avatar
Try resetting the light and see if it comes up again.
Press the trip and reset buttons while the car is off and hold them while turning on the car until the light comes off.
Old Jul 13, 2008 | 05:53 PM
Trackruner228's Avatar
That light comes on every 7500 miles to remind you to get the oil changed. Reset it and you should be fine.
Old Jul 13, 2008 | 11:15 PM
Forevafire's Avatar
cool thanks guys
Old Jul 14, 2008 | 10:17 AM
fsttyms1's Avatar
OR
On the back of the cluster you will see 2 or 3 little tabs in the center where each gauge is. Pend the up and the whole needle and face assembly will come out as one. Then plug that into your original cluster and see if that makes a difference (as there is some difference in wiring) Also unplug the VSA bulb
Old Jul 14, 2008 | 04:39 PM
Forevafire's Avatar
Cool I'm going to go try that now. Ill see what happens when I switch out the old one. Is it possilbe I can keep the white face but put my stock needle and gauge in the new cluster?
Old Jul 14, 2008 | 04:46 PM
fsttyms1's Avatar
Thats what you are doing. You remove the clear shield and black bezel, then on the back side you remove the gauge face and needle all in 1 assembly. DONT pull off the needle. The whole thing will come out and you can reassemble it into yours after removing the original assembly. That way you get to keep your original mileage as well.
Old Jul 14, 2008 | 09:23 PM
Forevafire's Avatar
Ohhhhhh ok. I understand now. I will attempt this tomorrow and let you know if I have any questions. Thanks fsttyms1
Old Mar 16, 2009 | 04:11 PM
italiancip14's Avatar
where can i get 99 tl reverse glow gauges?
Old Mar 16, 2009 | 07:14 PM
fsttyms1's Avatar
Ebay. You have to buy the 5 speed ones and trim out the dividers that go between the prn4321. IMO though the ones available for our cars dont look good.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
brandnewcolony
Sep 12, 2015 10:39 AM
