need some help-engine misfiring
Old Oct 31, 2008 | 04:01 PM
dgrott's Avatar
My 2000 Acura 3.2TL yesterday indicated a flashing CEL and now the TCS light came on. The codes pulled indicated multiple and random misfires (P0300) and misfires in 5 of 6 cylinders (all except Cylinder 5).
I replaced the EGR Valve and the spark plugs. I think now that it might be the coil packs. I have no idea which cylinder is #5 so I can swap the coil pack with #4 or #6 and see if the code switches to a different cylinder.
A description would be great and any other thoughts on what might be causing this would be great as well.
Thanks!
Old Oct 31, 2008 | 08:07 PM
Rajca's Avatar
wham bam thank you ma'am
firewall
1 3 6
2 4 5
radiator
thats how the cylinders look
did u check the gap on the spark plugs?, put seafoam in the intake port, the gas take and the oil. check out the seafoam thread
what kind of gas r u using? make sure all connections to the coil are tight.
Old Nov 1, 2008 | 08:25 PM
NSXNEXT's Avatar
Originally Posted by Rajca
firewall
1 3 6
2 4 5
radiator
You sure about that?
According to the Helms manual it goes:
Rear 1 2 3
Front 4 5 6
Firing order 142536
Old Nov 1, 2008 | 08:31 PM
Rajca's Avatar
that was from my memory, but if thats what it says in the helms manual that thats what it is.
Old Nov 14, 2008 | 06:16 PM
RACINGHART03's Avatar
Rear 1 2 3
Front 4 5 6
Firing order 142536
This is the correct cylinder arrangement.
kencepeda
Sep 26, 2015 05:13 PM
Chaptorial
Dec 20, 2009 02:14 PM
gtg975n
2G CL Problems & Fixes
May 8, 2007 03:20 PM
ocd_2k3
Sep 25, 2006 01:01 AM
