Need help to remove Front Bumper!
Old Nov 8, 2007 | 06:58 PM
azn_xxxd's Avatar
.a BUM with SMG...
Red face Need help to remove Front Bumper!
Could you guys help me or show me some pictures about the process of removing the Front Bumper , i need to change the Fog lights bulbs so , please help me guys
Old Nov 8, 2007 | 07:18 PM
01tl4tl's Avatar
look in DIY for replace headlight housing
basically there are some plastic tabs underneath and 1 or 2 scews/bolts at the ends
It pulls straight off from there
requires 2 people so you dont mess it up putting back on
Old Nov 8, 2007 | 09:45 PM
azn_xxxd's Avatar
.a BUM with SMG...
lolz hhehe hey 01TL4tl, can you explain one more time , more simple man ,cuz lolz i don no anithing about cars lolz , so what is the DIY , and wat is the headlight housing , OR it would be great if some one has pictures.. thanks
Old Nov 8, 2007 | 10:26 PM
01tl4tl's Avatar
if you look in the main list of threads for gen2 one of the titles is DIY, that Do It Yourself, many things you can do to a TL are there with full pics and tips from other members
Probably one for foglist install - that will show you too
for the bumper- look under the front bottem of the car for plastic things that hold the panel in
remove them- about 5 I think it was
then on the end of the bumper where it goes around the side of the car, there are srews or bolts there- remove those and the whole front cover should come off- if it doesnt- find the thing still connected
Old Nov 8, 2007 | 10:27 PM
philly fresh's Avatar
Its good to be FRESH!!
looking up from the floor to the sky laying on your back, there are two 10mm bolts at the farthest part of the bumper from the center. then two 10mm bolts at the corner of the bumper under the headlight in the wheel well area. then i belive like 6-8 push clips. try not to break them they are 2.41 at the dealership. i had to buy 8, total was 22 bucks. then just wiggle it out and it comes out nice and easy
Old Nov 9, 2007 | 07:41 PM
Rsoetidjo's Avatar
Rich
https://acurazine.com/forums/showthr...t=resonatorand
This will help you.
But if you only want to change the bulb for the fog light.
You don't have to take the bumper off.
Go look underneath the car, behind the front bumper/ front of the wheels.
Take the 2 plastic clip off (hold the black plastic cover).
After you take them off you can pull the cover down, and you should can fit your hand there.
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
leerbgdup
Sep 6, 2015 11:01 PM
Sixers12
ILX
Sep 6, 2015 07:54 PM
robowarrio
Sep 1, 2015 09:25 PM
