Changing rear door side arm rest, how?
Old Oct 28, 2007 | 03:59 AM
hooked2TL's Avatar
Hi,
My passenger side rear door armrest seems to have separated and become out of form. I've tried gluing it back but it keeps pulling away. Would appreciate your tips on how i can go about removing this arm rest and replacing with a new one.
Attach is photo of the problem. I wonder if anyone's had this as well. No one ever sits back there but for some reason, this has occurred.
http://www.pbase.com/sams_photos/image/87983847
It seems the arm rest itself has become de-form, and has pulled away from the flat plastic window control pad.
Is this arm rest part of the entire interior door panel or is a separate piece, and how does one remove this to swap out?
Thank you in advance.
Old Oct 28, 2007 | 08:33 AM
mzahidi's Avatar
same here...
anyhelp?
Old Oct 28, 2007 | 09:27 AM
Bob_F's Avatar
This is a fairly common problem on the second generation TLs and there are many threads discussing this. Try searches with the terms "armrest" and "glue". There is a great thread somewhere with a step by step "how-to" for a DIY repair involving glue. If I recall correctly, that thread was on the CL forum. (The CL can have the exact same problem.)
If I can find the thread again, I'll post it here.
Bob
Old Oct 28, 2007 | 10:19 AM
Bob_F's Avatar
OK, here's the DIY repair link that I mentioned above:
https://acurazine.com/forums/showthread.php?t=187099
And here's another thread on this issue from the CL forum:
https://acurazine.com/forums/showthread.php?t=186883
Old Oct 31, 2007 | 10:47 PM
hooked2TL's Avatar
Bob,
Thank you for the links. They were very helpful and i've now glued back the armrest by following the great tips in the links.
For everyone, when you take out the two screws, one little one behind the door lever, and one bigger one tucked away inside the armrest, there's nothing else holding the interior panel aside from the clips inside it. Starting from the edges of the panel, i just slowly pried the panel away from the door. You should hear the clips pop as they disengage from the door.
I used gorilla glue the armrest together. The design seems rather poor as there was very little material holding the foam part of the armrest to the plastic frame. It was going to pull away eventually, and mine did. This glueing job actually will make this much stronger than before.
sam
Old Nov 9, 2007 | 09:13 PM
Bob_F's Avatar
Originally Posted by hooked2TL
Bob,
sam
You're welcome for the help and thanks for the update and the repair tips. That's great that your repair went well.
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
handsom-hustla
Nov 13, 2015 05:04 PM
obert
Oct 29, 2015 10:37 PM
Sep 4, 2015 08:03 AM
